Go Back   Automotive Forums Car Chat > Honda > Exterior | bodykits | Lighting
Exterior | bodykits | Lighting When your ready to showoff that 'H' ride, here's your forum!
Old 04-25-2002, 02:03 AM
iluvjasmine iluvjasmine is offline
trouble with Carbon Fiber hood
I just picked up my carbon fiber the other day. I was excited as Hell cause Iwaited for like three weeks for that damb thing to come. When i installed it i didn't even fit perfectly. One end was high than the other. Should I return it or is it normal. My friend who works at a performance shop said that those hoods never fit perfectly. He said he would fix it for me to make it fit. What should I do?
Old 04-25-2002, 02:19 AM
Rein Rein is offline
Send a message via AIM to Rein
I have no knowledge of carbon fiber hoods and fitting, but my guess is that you need hood pins. I guess that's why everyone else has them.
1998 Audi A4 1.8T
*APR turbo back exhaust
*APR 1.0 bar chip upgrade (+40 hp, 88ft-lbs)
*Axis Seven 18s
Future mods:
*H&R full coilover suspension
*APR Stage III+ Turbo Kit (310 hp, 345 ft lbs)
*Stop Tech Slotted Big Brake Kit
Click here to check out my car on Cardomain.com
Secondary car: Black 1992 Civic Si
"Every man dies. Not every man really lives"
Old 04-25-2002, 12:46 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
honda's and aftermarket body parts never fit right, but on the hood, there should be rubber stoppers that can turn to raise and lower a part of the hood, if not you can try shimming up the low side so at least its even, but chances are you will be hard to find a perfect replacment.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 04-25-2002, 01:48 PM
emadboy200's Avatar
emadboy200 emadboy200 is offline
Send a message via AIM to emadboy200 Send a message via Yahoo to emadboy200
I agree with crxlvr. You should try moving the rubber stoppers up and down to see if that helps. You might want to make sure the hood isn't warped either. If it is I would send it back in exchange for another.
Old 05-02-2002, 12:07 AM
legacyciv legacyciv is offline
Send a message via AIM to legacyciv
I have the same prob w/my hood. Fits but it's not perfect like the stock fit. Good luck!
Original PH member registered Nov 2000
Old 05-07-2002, 04:37 PM
LegacySpeed's Avatar
LegacySpeed LegacySpeed is offline
Send a message via AIM to LegacySpeed
It's tough to find a CF hood that fits right. I guess what happens is it gets messed up when they pull it out of the mold. Like Legacyciv said, his had a similar problem. Maybe they'll swap it out for you, but chances are they'll all have some sort of flaw.
www.team-legacy.org
Old 05-08-2002, 12:20 AM
desikoncepts desikoncepts is offline
Banned
Send a message via AIM to desikoncepts
i had the same problem with my cf hood. i had to get hood pins to make it stick down. u have to get them anyways for safety so u might as well get some hood pins to hold it down right.
Old 05-09-2002, 05:46 AM
sparq's Avatar
sparq sparq is offline
AF Premium User
Send a message via AIM to sparq
You dont "always" need hoodpins...
And what kind of CF hood is it? But I agree, its not just HONDA body panels but alot if not ALL companies, its hard to reproduce the exact fit because its not like the companies actually release the panel molds for aftermarket companies to use... so they have to go with what they got... but so long as it does go flying off, enjoy
AF's Official Asshole
RIP AUNIE
Need Help With Carbon Fiber Hood wolfpack43acc Exterior | Bodykits | Lighting | Aerodynamics 0 08-01-2007 11:29 AM
Is $600 high for a Fiber Images Carbon fiber hood? LX98Civic '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 15 08-28-2002 01:25 PM
iam having trouble puting on a carbon fiber hood ...can some one give me advise?? iVteC_bOi Graphic Manipulation 5 08-15-2002 10:53 AM
Help With Carbon Fiber Hood??? ex2fast4u Exterior | bodykits | Lighting 3 06-18-2002 08:22 PM
