Go Back   Automotive Forums Car Chat > Cadillac > Escalade | ESV | EXT
Old 04-23-2002, 04:20 PM
the Wizard the Wizard is offline
Programming a new remote??? Help
Hi guys,
Can anyone tell me the procedure to program a new keyless remote to a 2002 Escalade?
Thanks
Old 05-13-2002, 01:37 AM
bruceb bruceb is offline
you can try this company: http://www.keylessride.com
they were able to reprogram my remote for a lot less money than the dealer wanted.
-bb
Old 09-23-2002, 03:29 PM
djhookertj djhookertj is offline
Send a message via AIM to djhookertj
ok
all you do is shut the doors turn on key two times leave on and then hold the new remote lock and unlock buttons at the same time for 30 seconds and voila i do it all day everyday thios works
Old 04-21-2004, 12:25 AM
thepartsyouneed's Avatar
thepartsyouneed thepartsyouneed is offline
Banned
Re: Programming a new remote??? Help
Note: Before starting this procedure, ALL transmitters must be present.
Turn Ignition Switch to OFF.
Ground pin 4 (BLK-Ground) to pin 8 (BLK/WHT-Keyless Entry Program Enable Signal) of the Data Link Communications Connector (a.k.a. DLC, Under the left-hand side of the instrument panel, left-hand side of the steering column, mounted to the bottom of the knee bolster). The receiver will respond by locking and unlocking the doors, and activating the liftgate window release (if equipped) within 2 seconds.
Press and hold the LOCK and UNLOCK buttons simultaneously on the first transmitter to be programmed until the locks cycle (approximately 10 seconds).
Repeat step for up to four total transmitters to be programmed (if available). The receiver will respond by locking and unlocking the doors and activating the liftgate window release (if equipped) within 2 seconds.
Remove the ground applied to the DLC.
Lock and unlock the doors in order to verify the transmitter operation.
Activate the rear window release in order to verify the transmitter operation. Repeat programming procedure or replace transmitters as necessary.
Dealer says new computer needed to program keyless remote, I think they are wrong.. hoover101 Sequoia 2 03-16-2010 11:17 PM
96 Camry CSI Program Keyless Remote JeanC Camry/Camry Hybrid/Vista 1 07-15-2009 12:28 PM
Program New Remote for EL Flalcon XTHOMMOX Falcon | Fairmont | FPV 4 11-21-2008 06:51 PM
95 maxima GLE, how to program new remote khurramahmed Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 4 04-23-2007 01:40 AM
How to erase all remote control codes before programming new remote brandyf 4Runner/GX470 0 01-10-2004 05:42 PM
