Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 01-10-2004, 05:42 PM
brandyf brandyf is offline
How to erase all remote control codes before programming new remote
Here's the instructions I received from my dealership for my 1997 4Runner. Please keep in mind that this all must be done very fast and I would recommend you have someone that can tell you when the LED flashes so that you can concentrate on pressing the programming switch. This is a very frustrating process or at least it was for me and my husband. If this does not work for you - you are not doing it fast enough.
__________________________________________________ ___________
Factory Supplied PIO/DIO Wireless Door Lock Remotes
1996-1999 Models (and 2000 Tundra)
RS3000
REMOTE CONTROL PROGRAMMING
To erase all REMOTE CONTROL codes from the system:
1) Insert the key into the ignition switch, and turn it to "ON".
2) Press and hold the ECU's PROGRAMMING SWITCH for 3 seconds.
The STATUS MONITOR LED turns on for 5 seconds.
- YOU MUST PERFORM THE NEXT STEP WITHIN 5 SECONDS -
(I believe that this next step must be performed within the 5
seconds on #2.)
3) Press and hold the ECU's PROGRAMMING SWITCH for over 2
seconds again. The STATUS MONITOR LED turns off, then flashes 3
times. The PIEZO "CHIRPER" chirps 3 times, and the exterior
(outside) lights flash 3 times.
4) Turn off the ignition. The ECU has cleared all REMOTE CONTROL
codes; until another REMOTE CONTROL is programmed, the system
will not work with any REMOTE CONTROL.
__________________________________________________ __________________________________________________ ______________________
Dealer says new computer needed to program keyless remote, I think they are wrong.. hoover101 Sequoia 2 03-16-2010 11:17 PM
programming new remote control for 96 Impala SS queensbridge_66 Impala | Impala SS 1 04-19-2009 10:54 AM
Remote Control Buy & Programming Ferny_71 Impala | Impala SS 2 07-15-2007 12:09 AM
95 maxima GLE, how to program new remote khurramahmed Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 4 04-23-2007 01:40 AM
