Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 11-14-2005, 12:39 AM
khurramahmed khurramahmed is offline
95 maxima GLE, how to program new remote
i bought 95 maxima GLE, which came with one dealer installed or factory installed keyless alarm. car alarm system is working properly, but remote is not working, i replaced the bettery but still wont work.
does anyone know how to check if remote is bad or something else is wrong. i am also interested in buying a new remote .
can anyone tell me how to program a new remote for this car.
Old 11-14-2005, 11:41 AM
BP2K2Max's Avatar
BP2K2Max BP2K2Max is offline
Send a message via AIM to BP2K2Max
Re: 95 maxima GLE, how to program new remote
you may have a weak car battery. when my car batter was dying in my 95 maxima my remote stopped working, when i finally got around to getting a new battery it started to work again. i don't wanna say that's definitely the problem but that's what happened to me.
you could also try to reprogram it:
Programming Instructions from the Nissan/Infiniti Factory Shop Manual
First, for entering "Setting mode": (1) Close and lock all doors. (2) Insert
and remove the key from the ignition more than six times within 10 seconds.
(The hazard warning lamp will then flash twice.) At this time, the original
ID codes are eliminated.
ID code entry: (3) Turn ignition key to "ACC" position. (4) Push lock
button on the new remote controller once (for example, if door is locked
using the remote controller during this ID code entry enable state, a new ID
code can be entered). At this time, the new ID code is entered. (The hazard
Additional ID code entry (5) If you need to activate additional remote
controllers, unlock the driver's door, then lock again with door lock knob.
(6) Push lock button on the additional new remote controller once. (7) This
ID code “entry enable state” and setting mode remain until the driver's door
is opened.
BP's Rides;
- 2005 Kawasaki Ninja ZX6R- Mods: ECU Jumper, Akrapovic Slip-on, Power Commander III, 8000K HID's.
- 2K2 Maxima 6 Speed-Mods: Advanced Timing, Cattman Cat-back Exhaust, H&R Springs, Tokico Illumina Struts, Konig Theory 19" Rims.
Old 11-15-2005, 03:07 AM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
You can try changing the battery in the remote - I don't know if you got a new one or are trying to program an old one - if that doesn't work, check out the link below
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 11-22-2005, 12:13 AM
Re: Re: 95 maxima GLE, how to program new remote
Thanks, it worked. my remote was good. i just programmed it and it worked.
thanks
is opened.
Old 04-23-2007, 01:40 AM
UKAV UKAV is offline
[quote]
....you could also try to reprogram it:
warning lamp will then flash twice.)...........
I tried to reprogram my 2K Nissan Cefiro (=Infiniti I30) remote using your instruction, I got through the step 3 OK but couldn't get the new ID comfirmation hazard lamp flash again after pushing the lock button of the remote (step 4). Have I missed anything?
