Old 04-23-2002, 10:29 AM
MaxSE's Avatar
MaxSE MaxSE is offline
Fix My Lights!
major problem people! i need your opinion. While working on the rear lights for my ITR, i had a slip up and put too much paint on them, so i said no prob, i'll just work around it. blah blah blah, few hours later.. realized that it looked like crap. Now i want to start over again, so here is my question to you. What is the best way to clean off paint from these plastic parts without damaging or hazing the plastic? I've tried paint thinner before on other clear parts as such, and now my tamiya S2000 doesn't have the clear lenses over the rearlights anymore! meaning thinner cracks the part!!! so any sugestions?! oh and by the way if this makes any difference, i used testors enamel to screw up my lights.
please help!
thanks in advance, i know you guys will come through!
Say NO to wheel gap...
Old 04-23-2002, 11:37 AM
87accordlx's Avatar
87accordlx 87accordlx is offline
Send a message via ICQ to 87accordlx
castrol super clean works well, pick some up at yourl local walmart, it won't damage clear parts
Old 04-23-2002, 11:54 AM
BVC500 BVC500 is offline
"409" also works and is less toxic than oven cleaner. just put some 409 in an empty paint bottle and put the clear parts in it. It may take 24 hours, but it will take the paint off. Use a toothbrush to remove the paint too.
Old 04-23-2002, 01:08 PM
MaxSE's Avatar
sorry but what's 409?
Old 04-23-2002, 03:51 PM
its a cleaning agent, can buy it in most grocery stores.
Old 04-23-2002, 08:20 PM
primera man's Avatar
"P-Man"
Most oven cleaners will do the trick.
I use MR MUSCLE....dont know if you get that over your way
View All My Models Here.
Old 04-23-2002, 09:26 PM
Protek's Avatar
Protek Protek is offline
Send a message via AIM to Protek
Formula 4 0 9
Make it idiot-proof and someone will make a better idiot.
Caution: I drive like you do.
Old 04-24-2002, 08:41 AM
MaxSE's Avatar
Thanks guys, i'll give it a try!
Old 04-26-2002, 01:07 PM
liang liang is offline
Guys, just a short question, will Castrol superclean be able to remove lacquer paint a couple of months old?
" Increase speed when being overtaken "
Old 04-26-2002, 03:04 PM
Jay! Jay! is offline
Horizontally Opposed
I've used it to remove Tamiya synthetic lacquers that were plenty old, but I have had little luck using CSC to remove some Gunze Sangyo spray paint, which is also lacquer, IIRC. Some of it is coming off, but not all...
Hierarchy of Subaru:
(Click to see mine!)
Old 04-29-2002, 11:27 AM
MaxSE's Avatar
Bigger problem guys! despite all your tips on using over cleaner, 409, etc. i couldn't get off my lazy ass and go buy some. Therefore decided to use thinner. I figured that if i was light on the lenses, that it would only "fog" up, but not crack.!!!! .....anyhow now i'm left couple bits if cracked plastic, which i'm really pissed about! does anyone out there have a set of clear lenses, or even painted fujimi honda integra lights they would like to donate?!?!?!? I don't care as long as they are still intact! Thanks!
Old 04-29-2002, 05:15 PM
daggerlee's Avatar
Well, you live and you learn
Be more patient next time!!
Dan
Old 04-29-2002, 06:04 PM
patate's Avatar
patate patate is offline
cast your lens in clear resin(and whit this technique you could do real altezza taillight or anything else)
Old 04-30-2002, 09:20 AM
MaxSE's Avatar
In clear resin? what kind of look will that give? well resin is a clear plastic isn't it? or some type of plastic? is it difficult to work with, and i've also heard it's expensive...can someone please give me the lowdown on resin. As sad as that may sound.
TIP: Fix those doorjam switches // no dome light... Intuit Escort 3 11-21-2009 10:27 PM
99 Sunfire Dash Light & Radio Lights turn off when you turn on head lights fathershrubb Cavalier Problem Diagnosis 5 04-20-2009 04:26 PM
Flip Up Lights vs. Fixed Lights freakonaleash1187 Car Comparisons 15 01-31-2004 12:00 PM
fixing lights in 89 camry wagon rizzo420 Camry/Camry Hybrid/Vista 0 12-06-2003 04:01 PM
