Old 04-21-2002, 08:03 PM
LuDiCrAzE LuDiCrAzE is offline
My Door Won't Lock...?
I have a 97 accord and when i hit the power lock switch, the passenger side will lock, but my side will just make a sound for about a second. The weird thing is, when I lock the door from the outside, it will work. Does anyone know what's wrong? Thanks for any help.
Old 04-22-2002, 02:48 PM
Tireburner's Avatar
Tireburner Tireburner is offline
There is are lock detection wires that comes out of drivers latch/actuator. It has to have ground on the black/red to stay unlocked and ground on the blue/ white to stay locked. Generally locking the doors through the pass. door key cylinder will make the drivers lock or unlock properly.
Replacing the latch/actuator is generally the only means of solving the problem.
Why isn't common courtesy more common?
Old 04-23-2002, 03:46 PM
Thanks for the help. I'll check into this as soon as possible.
Old 04-25-2002, 09:34 AM
onesojourner's Avatar
onesojourner onesojourner is offline
Send a message via AIM to onesojourner
i dont know about your car but on mine i have to hold the handle out when i lock it from the inside
don't like my post
The things you own end up owning you-Tyler Durden
videos
Old 04-25-2002, 08:19 PM
CraniumDesigns's Avatar
CraniumDesigns CraniumDesigns is offline
Send a message via AIM to CraniumDesigns
that is normal. my 1996 civic does the same thing. it is a security measure implemented to keep you from locking your keys in the car while the door is still open, the only way to lock your driver's side is to either have the door closed or to pull up the door handle while it is open.
Steve Davis
AF Bay Area Crew
WEB DESIGNER!
www.craniumdesigns.com
'00 Window driver side window won't roll down, door won't lock pb1998 Windstar 6 05-29-2010 06:46 PM
03 Optima Door Won't Open cmbsound Optima | Magentis | Lotze 1 09-30-2009 10:34 PM
Doors won't lock in car / Keyfob doesn't work SilverPony2001 Corolla/Matrix/Voltz 1 01-27-2005 11:28 AM
1986 Cherokee Laredo Doors Won't Lock byroan Cherokee 1 01-23-2005 10:03 PM
Doors won't lock! Window lift arm bent! Iriss 3 Series 0 03-03-2003 12:02 PM
