Old 05-05-2005, 11:10 PM
Technoman's Avatar
Technoman Technoman is offline
Old Cartograf decal problem
I am just at the point of applying the decals to an old Esci Fiat 131 (The rare ESCI sponsored one) and I am having a problem. The decals look to be in fantastic condition and have been bagged up for years with a protective greaseproof sheet over them. When viewed under light there is no cracking or anything. However, when I dipped one decal, waited a minute or so then tried to slide it off the backing paper it broke up into small pieces, it seems to break where the clear is very very easily.
I have stopped for now so as not to ruin any more of the decals which I am guessing would be impossible to find, but was wondering if anybody knew what was wrong or if there is anyway to stop this from happening? Can I put something on the decals before transferring them to keep them together for example?
Any ideas would be greatly appreciated as I would love to use the original decals on this car.
TIA
AJ
Not so recently completed, I will get another done soon...:
  1. Fiat 131 Rally - ESCI Sponsor
  2. Taisan Starcard 911 GT2
  3. Zexel Skyline R32 GT-R Gr.N
  4. Sierra Cosworth RS500 ANZ
Old 05-05-2005, 11:30 PM
druid_99's Avatar
druid_99 druid_99 is offline
Never get this problem yet (not for the moment) but just a suggestion (maybe someone can tell me wheter it should or should not be done), I think applying a coat of clear on it might help. (or might not help, it's my own theory that I've never tried )
What is understood need not be discussed
Old 05-05-2005, 11:47 PM
scaleracecars scaleracecars is offline
Re: Old Cartograf decal problem
TIA
AJ
http://www.scaleracecars.com/Merchan...e&Store_Code=S
This is what you need. It is Microscale liquid decal saver. Works perfect and easily not to mention very inexpensive.
Best Regards,
David
Old 05-05-2005, 11:59 PM
Technoman's Avatar
Re: Re: Old Cartograf decal problem
Best Regards,
David
Outstanding, looks perfect, do you just brush it on?
I will thank you for your sound advice by ordering this directly from you...
Old 05-08-2005, 08:28 PM
Re: Re: Re: Old Cartograf decal problem
You wil want to apply the film with the largest softest brush you can find . 3/4 inch wide works well. Lay it on thick in one pass. It will level out perfectly and get very thin. Trust me on this. It would be almost impossible to get it on too thick.
David
Old 05-08-2005, 08:30 PM
Vric's Avatar
Vric Vric is offline
Microscale Liquid Decals Film will solve this problem
Old 05-09-2005, 09:25 PM
Technoman's Avatar
Thanks guys, it shipped out today so hopefully I can crack on with this in the next day or two. Thanks for the fast turn around on the order David, excellent service again.
AJ
Old 05-12-2005, 06:38 PM
Technoman's Avatar
Wow, this stuff is AMAZING!!!! I can not believe I ever lived without this stuff.
Thanks David for the tip and speedy service, the other decals I ordered from you arrived in great condition too.
Old 05-12-2005, 06:42 PM
RallyRaider's Avatar
Zomby Woof
On the topic of Microscale liquid decal film, has anybody ever tried spraying it through an airbrush? I've used it on some laser printed decals and it left brushstrokes, not much but noticeable close up. I wonder what you could thin it with?
Old 05-12-2005, 06:54 PM
Vric's Avatar
I did. The coat will be too light. you really need to make about 8 to 10 coat of it. For me, Lacquer and other stuff I usually use didn't clean the airbrush and it kiled my Aztek.
Old 05-12-2005, 06:58 PM
Zomby Woof
Do you mean laquer thinner couldn't clean the dried up liquid decal from the airbrush? Sorry man, that's nasty!
Old 08-06-2005, 09:58 AM
Cychalen's Avatar
Cychalen Cychalen is offline
My question is also about Microscale Liquid Decal Film so I am not making a new thread.
Will Microscale Liquid Decal Film protect decals from cracking and yellowing over time?
I did not clear coat the decals on my first few models. What I have in mind is to apply it on the decals (for protection) rather than clear coating them.
Old 08-06-2005, 01:20 PM
You can apply it over the decals even after having them on the car but I would not suggest this unless you plan on coating the whole car. There is little to be gained unless you have a problem with the decals now.
In the case where you have an entire car covered with decals you can do this and it helps to give the decals a uniform look and seal them together but I don't think it will keep them from yellowing. As for cracking I hever never seen a decal crack once applied unless the model was coated with future floor polish or if Tamiya spray clear was applied wrong.
David
Old 08-06-2005, 07:05 PM
Zomby Woof
If all you're after is providing some protection for the decals, waxing is probably a better solution.
