Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 04-08-2002, 09:05 PM
PoisonFangs PoisonFangs is offline
Banned
Send a message via AIM to PoisonFangs
Long term engine life with turbo. PLEASE READ!!!!!!!!!!!!!
I have an 02 civic ex. I have yet to find a company that makes a turbo for my car but i want one when they come out. I have a stock engine and dont want to swap. I was wonderin if anybody knows what if any are the long term damages with a turbo on my engine. HOW LONG WILL IT LAST?
Old 04-09-2002, 11:29 AM
97teg 97teg is offline
it all depends on how much boost you run and if you're going to build up the bottom end first. another important factor is to upgrade the fuel side. considering you want to run on stock internals, dont run more than 7 or 8 psi but you're still gambling on whether you blow it or not. upgrading the fuel stuff is a must and i suggest building up the bottom end to handle the boost if you want to make sure you dont blow your engine.
Old 04-09-2002, 01:18 PM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
You should be safe to run 7PSI just fine. As you build up the motor then you can start running up to 10PSI and higher.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Old 04-09-2002, 02:31 PM
SleeperTeg's Avatar
SleeperTeg SleeperTeg is offline
Most important thing to watch with turbo (or any FI) = a/f gauge.
Go lean and melt your engine into the oilpan.
Correct me if im wrong on this issue.
02' VR6 problem with shifting... please read 2002vr6krys GTI 7 05-17-2010 03:19 PM
need help identifing a 16g turbo please read asap!! boostdog Off-Topic 5 01-08-2005 11:25 PM
I got a 1992 plymouth laser rs turbo please read!!!! TMUMMY Off-Topic 21 09-21-2004 04:24 PM
91 300ZX Non-Turbo....Please Read steven15 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 13 09-03-2004 01:36 PM
Whats up with this??? please read! morgnum Lancer 2 03-01-2002 10:14 PM
