Go Back   Automotive Forums Car Chat > Volkswagen > GTI
Old 01-09-2005, 10:26 PM
2002vr6krys 2002vr6krys is offline
Exclamation 02' VR6 problem with shifting... please read
i drive a gti vr6 2.8L and lately i have been having problems i thought was caused from cold weather but it has warmed up and the problem consist.
When i shift from 1st - 2nd and so on... in btwn. each gear there is a big lag when i accelerate. almost like the car jumps. the tach light will go up with acceleration and then drop and then go up again even with consistent acceleration. Like the car lags behind when i need to go fast. i never had this problem before... and i hate the dealership closest to me... they are not friendly
i thought it may be the fuel injectors so i put some RXP and the problem has not been as bad but is still there. the car is only 3 years old now and i wouldn't think the fuel injectors would go bad... or could they?
any suggestions?
Old 01-10-2005, 05:02 PM
boschmann boschmann is offline
Re: 02' VR6 problem with shifting... please read
Do you think the clutch might be slipping?
Old 01-10-2005, 05:04 PM
miles213 miles213 is offline
perhaps it is the fuel filter or fuel pump. or maybe a one of your belts. does the engine "choke" at higher speeds or steady high rpm's? being an 02 you should still under warranty, just take it in and find out for sure.
Old 01-24-2005, 08:28 PM
this is my first manual transmission... what are signs of the clutch slipping, and is it possible it would be covered under warranty? The problem is really bad when it's really cold outside and when i first drive it... after the car has warmed up a bit, the problem is still there but not as bad...
Old 01-25-2005, 05:09 PM
you are covered up to 50k miles. take it in.
Old 01-25-2005, 08:24 PM
A slipping clutch more easily felt if you have the engine revved past 3000 rpm in third or fourth gear and make a quick shift to the next gear, letting the clutch out quickly and hitting the gas hard. The rpm's should drop quickly and not let the engine rev up then slowly come back down.
Old 05-17-2010, 03:16 PM
Gtivr698 Gtivr698 is offline
Ok, mine did the same thing and i had misfiring cylnders, but it could also be your throttle body, If you have a bad throttle body when you get on it, the throttle reaction will lag or not be good. And also your clutch could be slipping
Old 05-17-2010, 03:19 PM
And when your clutch slips it will feel like your car chugs, you will deff feel it,
