Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 04-08-2002, 02:59 PM
rosman4u rosman4u is offline
Engine parts need to for hybrid swap
Hey guys, I'm swapping out my motor for a b16a, before I do I will build up the motor, no bottom end parts just upper, the list is as follows:
Port Polish Head & intake
Underdrive pulleys
Cam gears
AEM Cold air intake
Throttle Body
Type R cams
Venom Fuel rail
Headers
Which car should I order my parts from? 94-01 Integra? example for the pulleys, cam gears, throttle body should the parts from the vtec integra fit on my b16a? any help is appreciated.
Old 04-08-2002, 03:11 PM
91zc 91zc is offline
Use B series parts. The ones from a 94-01 integra Vtec will work. I used a GSR pulley since my stock one came with a big chunk missing
You should also be able to use a 99 Si header. I have heard that it bolts right up.
91 civic 4dr
b16a
14.8@94
Old 04-08-2002, 03:49 PM
Hey man, thx for the reply, will start the frankenstein project this week.
Old 04-08-2002, 05:36 PM
I forgot for the intake you are going to want to use an 88-91 Si/Ex intake or get a 99 Si intake and relocate your battery.
91 civic 4dr
b16a
14.8@94
parts needed for auto to manual trans swap for 2000 Civic Si??? blackbeauty00' '96-'00 Civic 6 09-30-2007 02:35 PM
gathering parts needed for transmission swap, help needed Zankin 3000GT/Stealth 3 12-13-2004 02:49 AM
Parts needed for a RB25DET swap JDMWRX 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 2 12-31-2003 08:03 PM
Parts Needed for b16 swap dohcCRXvtec Engineering/ Technical 1 06-01-2002 03:45 PM
