Old 04-07-2002, 07:59 PM
spy54's Avatar
spy54 spy54 is offline
Send a message via AIM to spy54
hydro to cable?
isn't there somethign i can get that iwll allow me to put a hydro tranny in my crx? its cable right now
AF Teen Crew
Purehonda.com - may she rest in peace
1996 Chevy C1500, Flowmaster Exhaust, Tinted Windows, 2 Kicker 10" L7 Subs, Eclipse 5v headunit, Alpine V12 Amp
DJM 4/6 drop kit being sold
Full Throttle 9.5 inch lift being installed
1989 CRX si "silver mist"---SOLD---.....Stripped and Wrecked in Compton
corbeau forza 2 seats, DC short shifter, Powerslot slotter rotors, AEM brake pads, Bfgoodridge Stainless steel brake lines, Greddy MX exhaust, AEM Cold Air Intake, Konig Rated-R rims, Kamikazi header
Make an Offer [email protected]
Old 04-07-2002, 08:22 PM
DreamsofaCobra DreamsofaCobra is offline
If you mean a hydraulic clutch release, it probably can be done. When replacing the tranny in my mustang with a manual, the cable was not a practical option (due to the headers). I opted for a hydro kit for a late model mustang. hydraulic clutch needs several things. A master cylander, with mounting adaptor and pedal connection, the fluid line, (I opted for braided steel) and some sort of slave cylander attatched to the throwout bearing. In my kit the slave was attatched to the throwout bearing directly, and mounted on the inputshaft retainer. I have seen kits where the slave attatches to the same throwout bearing arm that the cable attatches to. I am not too familier with frontwheel drive clutch setups, but with all the honda tuners out there, I am sure someone has made a kit. (fabricating one would most likely be to difficult without machining equipment) Search google and I am sure something will come up.
Old 04-08-2002, 10:09 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: hydro to cable?
www.hasport.com
they make a kit for it for like 150.
Old 04-08-2002, 04:44 PM
spy54's Avatar
naw isn't that cable tranny into a hydro car? i need hydro tranny into a cable car
AF Teen Crew
Old 04-08-2002, 10:09 PM
mellowboy's Avatar
No i'm pretty sure that they sell the kit. from cable to hydro thats wat u said rite?
Old 04-08-2002, 10:44 PM
spy54's Avatar
i'll call them up and wednesda and see what they can do for me
AF Teen Crew
Old 04-10-2002, 07:48 AM
5_LiTeR_EaTeR 5_LiTeR_EaTeR is offline
Send a message via AIM to 5_LiTeR_EaTeR
I don't think they make adapter kits for hydro to cable but I know for a fact that they do make cable to hydro kit adapters.
Old 04-10-2002, 07:50 AM
ohh yeah... just wondering what are you swapping or trying to put into what here? I hope you aren't trying to swap a SIR-II into a CRX... thats too much work... but if you are just swapping different generation trannys then it should bolt up.
how can I open tailgate when cables were not put back correctly kimm5 General Discussion 2 07-10-2010 06:24 PM
2000 SEL 3.8l Battery Cable Hot !! Nox Windstar 2 06-12-2010 12:06 AM
1985 Caprice leaks at speedometer cable Jeffesong Caprice 6 08-23-2009 10:55 PM
2005 Wrangler shift cable linkage DrRadar Wrangler 1 04-14-2009 11:24 AM
