Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 07-18-2009, 06:02 PM
Jeffesong Jeffesong is offline
1985 Caprice leaks at speedometer cable
Anyone replace their speedo cable? Mine leaks everywhere and the speedomoeter actually fluctuates rapidly when I drive. It leaks so much fluid I cant drive the car anymore.
Old 07-21-2009, 04:26 PM
caffeineaholic's Avatar
caffeineaholic caffeineaholic is offline
Re: 1985 Caprice leaks at speedometer cable
I had to replace my spedo cable a while back for my '85 Caprice, but there was no fluid in it and if I remember right it had graphite in it for lubrication -- perhaps this isn't normal either? I'm not a mechanic and wish I could be more help; if I were to guess I would guess that something is wrong with the transmission and that tranny fluid is leaking into the cable...
What does the fluid look like or smell like? Is it a dark brown or red? More details would help; also when did the problem start? Does the transmission have any known issues?
1985 Chevy Caprice small-block V8 305ci (5.0L) - 4-Barrel Q-Jet (E4ME) - 700R4 - 115k+ mi. - resonator and A/C components deleted.
Driven in severe weather most of the year (Arizona 100+ degrees during summer heat or in wet weather especially in harsh monsoons). About 30/70 highway/city driving.
Old 07-21-2009, 06:02 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
The cable is not designed to seal oil in.
It's the speedo drive gear in the transmission tailstock that does the sealing.... and I think thats where your leak originates.
Old 07-23-2009, 08:14 PM
j cAT j cAT is offline
the as mentioned tail shaft area of your transmission needs a O ring,,,where the cable is mounted...this is a small cost fix...I think one fastener and one O ring....
with this leaking usually the other seals must be leaking....
Old 08-23-2009, 08:02 PM
Thanks all for responding. I took the car in a had the front, rear and speedo seals replaced. No more leaking!
Old 08-23-2009, 09:56 PM
thats what I thought,,,it was not that expensive a fix..usually..
with this type of transmission and age ..I use a product called transmedic..I have a few 12 oz bottles for tranny leaks...
recently my sons manual 5speed tranny had leaks all over...not large but did leave spots on the pavement..one oz/quart of capacity...no more leaks after a few days...with automatic transmissions the use of this at every fluid replacement has prevented any of my vehicles from leaking over 100,000's of miles...
once these seals start splitting though its time to replace...
Old 08-23-2009, 10:55 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
If your speedo needle is still bouncing, you will need to disassemble and lube your speedo cable.
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Tags
cable , speedomeeter
