Old 04-07-2002, 07:02 PM
Tyrell's Avatar
Tyrell Tyrell is offline
What a recovery!
About 4 months ago, I nearly ruined my Tamiya Loctite-Zexel Skyline with a really bad paintjob.
it took me absolutely ages to strip it to the point where I felt I could make it look good again. (No CSS in the UK), but in stripping it, I managed to pull a hole in the edge of the rear bumper (fender) big enough to get a pencil through.
...I know, I know - but the cloth I was using to dry it snagged the plastic and a bit just "pinged" off, and I couldn't find it...
Anyhow, this gave me the excuse I needed to use my Revell Putty (Dificult to find Tamiya Putty too, over here - most stores only sell Revell adhesive etc.).
See if you can spot the repair.
No? Let me help you.
Turning the model over, you can see how I did this.
I took a rectangular piece of plastic from my spares box, "roughed it up" using coarse wet and dry and then "superglued" it to the rear of the bumper.
I filled it using the Revell Putty and left it for 24 hours to dry.
Sanding it down was easy, but after priming it, I discovered that it needed some more filling. (See, there is a *definate* need to prime your models )...
After sanding and priming for a second time, I'm ready to start the gloss work again. (Let's just hope I don't make a pig's ear of it this time, too)...
...The rectangle of plastic was small enough not to get in the way when the floorpan was put back on - I checked this before I started (for once). When the model is finished, you shouldn't be able to see it (unless you're picky).
I'm not daft enough to try to remove it, although that would make a "perfect" fix...
Regards
Mark
Old 04-07-2002, 09:14 PM
primera man's Avatar
"P-Man"
I had no idea at all were the repair was done....10/10 on a awesome looking job
View All My Models Here.
Old 04-08-2002, 03:04 AM
tazdev's Avatar
tazdev tazdev is offline
I'm still here
nice repair job
couldn't work out where the repair was.
Good luck on the kit they look real good when finished. It was my favorite model to make, my pride and joy.
p.s. make sure the front spoiler is FULLY glued before even attempting to fit to the base.
Old 04-08-2002, 06:27 AM
flyonthewall's Avatar
Car Mod guy
yeah, thats a top repair job! Its a good feeling when u pull off a good repair - beats that sinking feeling u get when u break the damn thing in the first place
Old 04-12-2002, 02:20 AM
tenzoracerevovii tenzoracerevovii is offline
yea man......a truly good save.....too bad my ITR was far beyone repair....the roof and all the pillars broke off.....could've made a convertible except the a-pillars broke off too......SNIFF SNIFF
i have type-r stickers on my bike, will it go faster?
-me
Don't you know, it's 10 hp for every sticker, 50 hp extra for every additional inch of rear spoiler behond stock height.
-obiewancoyote
What do you think about 200k on a 93 Honda Accord? tools951 Accord/TSX/Accord Hybrid 5 03-03-2011 01:30 PM
What Edelbrock Intake should i go with? inforcer958 General Discussion 4 02-14-2011 07:58 AM
Vapor Recovery system lennysatz 7 Series 0 06-19-2002 11:45 AM
Recovery bag spare parts.. evergreen Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 5 05-23-2002 04:09 PM
Recovery/tow straps brad77 Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 9 01-16-2002 05:03 AM
