Old 04-05-2002, 06:08 PM
changedagame108 changedagame108 is offline
Exclamation Emergency Problem! Need help asap!
Today I brought my car into the shop to rotate my tires. When my friend (shop employee) attempted to remove one of my wheel locks, it came out cracked. It seemed to be previously cracked before today because there was already rust on the crack. Now, there is a small part of the wheel lock lodged inside the lug hole. I went to 4 different shops and they claimed that they wouldn't dare attempt to chisel or drill out the remaining bit of the lock in fear of damaging my rim. So I'm basically screwed now. I can't take off the wheel because a bit of cracked wheel lock is stuck there. If I get a flat, I'm screwed because I can't remove the wheel. What do I do?! Is there any way to resolve this problem?
Old 04-05-2002, 06:26 PM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
a pic would be helpful for a better solution.
i'm assuming part of the wheel lock busted off and got jammed between the wheel and lug. if so, use some needlenose vice grips to grab it, then rotate it aroudn the lug until u can get it off.
Old 04-05-2002, 06:30 PM
I'm going to take a pic of the stuck wheel lock bit when I get home and post it. Then maybe you can confirm if the vice grip technique will work. Thanks for your help Drift.
Old 04-07-2002, 11:34 PM
jeffie7 jeffie7 is offline
Send a message via ICQ to jeffie7 Send a message via AIM to jeffie7
if it was me I would get a dremel tool and cut it out just take your time worse comes to worse you will knick the inside of the hole where the lug nut would cover up anyways
thats what I would do anyways that or take a nice round cutting blade for the dremel tool and cut 2 slits in it and use needle nose pliers to turn it
Jeff
Old 04-08-2002, 03:10 AM
kane2g kane2g is offline
Send a message via Yahoo to kane2g
i dont think that dremel tool will stand up to the lugnut, they are the only things that holds your wheel on, so they are made to be strong.
92 fastback 240sx AKA Ess1Tree Cuz its green, and hasn't moved in months.
Old 04-08-2002, 04:07 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
A dremel will do it, but it might be a bit fussy.
If you do damage the stud you can get new ones pretty easily, which leaves you with another option.
Cut the back of the stud, and push it through the wheel. then you just need to get another Stud.
And next time dont do up the wheel nuts so tight. Thats the only way it could crack. (unless it was defective)
Transmission Problems... Need Help Asap! Black_s10_Blazer S-10 6 08-04-2004 07:42 PM
electronic problems!!! need help asap!!!! ib1finepimpette 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 4 07-23-2004 02:20 AM
PROBLEMS need help asap! EnjukuRacing240sx 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 2 05-03-2004 06:49 PM
Transmission problems need help asap Escortissues Escort 1 10-10-2003 06:49 PM
Emergency Situation! Need help ASAP changedagame108 Tires and Wheels 6 04-09-2002 08:22 AM
