Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 04-04-2002, 01:58 AM
boingo82's Avatar
boingo82 boingo82 is offline
Can't polish a turd.
Question Car "creaks" when going over bumps in cold weather
I don't know whether to put this in suspension or maintenance, but here it is:
My car "creaks" (like leaning back in a loose wood chair, or leaning back in one of those metal ones that needs grease) whenever I go over bumps in the road. It does not seem to be related to steering but is almost certainly related to outside temperature. If the temp outside is above 60 degrees or so, it does not creak or creaks very little. The colder it gets, the noisier. The noise is almost certainly coming from the front end. My father says it may be the "sway bar". I hope someone can help me. I am too lazy to take it back to the stealership because that's 4 hrs of driving and their service dept closes at noon, so I'd have to leave at 9:00 my time and I work swing shift so it's not gonna happen.
Old 04-04-2002, 01:32 PM
rockola's Avatar
rockola rockola is offline
i've had that noise
I've had the same thing on my car when its below 40 or so but usually never hear it again after I get outta my driveway or after 5 minutes. I've inspected and found nothing and I dont lose sleep over it. If yours does it consistantly over your whole drive time then that may be worth a looksee but if it's brief then I would'nt sweat anyting serious.
regards
steve
Too close for Sidewinders........switching to guns
Old 04-04-2002, 02:43 PM
FlossinPrimera FlossinPrimera is offline
Send a message via ICQ to FlossinPrimera Send a message via AIM to FlossinPrimera Send a message via Yahoo to FlossinPrimera
get used to it, it is just your strut fluid, when it is cold it cavitates through the valves in the struts.
1994 Infiniti G20 5 speed (rebadged as Nissan Primera)
K&N, Enkei Type 11 GML, JVC KD-SH55 Digifine, Pioneer Pear-mica components, 2 12" round things that bang and a 400W amp to make them bang. Coming soon: ACT clutch, new half-shafts, HKS superform springs, KYB AGX adjustable shocks, $tillen STB, 17" König Toxxins with Yokohama Parada Tires (P215/40R17).
http://gforces.streetracing.org/
"I wish Captian Archer was as much as a racial bigot as Captain Kirk"
-Burt Weed
Old 04-04-2002, 08:45 PM
boingo82's Avatar
I don't feel that 60 degrees is that cold...seriously, it is very loud and creaks over every miniscule bump.
Old 04-05-2002, 02:06 PM
NismoPC's Avatar
NismoPC NismoPC is offline
If you are always hearing it, then your struts are probably shot. Ever replce them? If not, how many miles are on the car? Generally, the Nissan/Infiniti SR20DE factory struts will last anywhere between 45K-65K with harsher driving habits. That would be my guess.
Brandon
'96 G20 - modified
Old 04-05-2002, 08:05 PM
boingo82's Avatar
Well, I just bought it a month ago and haven't replaced anything. It has 96,100 miles on it. I don't know about the prev. owners but my driving habits aren't too harsh. So maybe this is the end of the first set?
Old 04-05-2002, 10:31 PM
NismoPC's Avatar
Don't know what mods your planning on doing, but if not too aggressive, then you might want to just get a set of KYB GR2's. They are better than OEM replacements and the cost is pretty decent as well for all 4.
Brandon
'96 G20 - modified
Old 04-05-2002, 11:24 PM
boingo82's Avatar
Sweet, thanks.
Old 04-22-2002, 12:59 PM
jayntguru jayntguru is offline
Check the bushings where your suspension subframe mounts to the body. Odds are the bushings are toast. I keep finding lots of P10's with this problem. As a test, spray the rearmost bushings with WD40 and it should quiet down for a while.
You cannot get the bushings seperate, and the whole factory subframe is about $325 with discount, without getting it shipped.
-Jay
1993.5 G20
http://www.nx2k.com/G20/
11 second GSX
http://www.nx2k.com/eclipse/
Old 04-22-2002, 07:57 PM
boingo82's Avatar
That is NOT what I wanted to hear.
Thanks.
Old 05-24-2002, 10:35 AM
petemc53555 petemc53555 is offline
It sounds as if it could be the "third link" at the top of the front suspension (in the wheel well) there is a ~6" long suspension component w/ two bushings in it. grab and wiggle you may have found it. I replaced mine @ 135K and squeak is gone. good luck
Old 07-06-2002, 12:56 AM
vikon vikon is offline
Hey,
It could be the upper spring insulators...There was a TSB issued in 96 regarding the clunking noise from the front...It was due to upper spring insulator design...It applies to all vehicles built before 02/96. Does the problem get worse in wet weather?
Old 07-06-2002, 05:34 PM
boingo82's Avatar
Wet weather?? What's that?? Sorry, only rain this year was .03" in April. I'm in the freaking desert. I don't know if it affects the noise at all. What other way could the cause be identified?
Just because offense is offered, does not mean you have to take it.
Old 07-06-2002, 07:22 PM
Hey,
It was just a suggestion of a possible cause...here is the TSB itself..
Regards,
Viktor
Old 07-06-2002, 07:27 PM
boingo82's Avatar
Thanks for the scan. I don't think that's my problem, as humidity has been 0% for months, but it's likely to help someone else experiencing clunking.
2008 Ford Taurus X crunching noise when going over bumps humbug1 Freestyle 4 01-30-2009 06:05 PM
Popping noise over bumps, cold weather Highbeamz Grand Prix 3 12-22-2008 08:23 PM
Front End Popping noise when going over bumps BlazerLT Blazer 21 10-24-2004 01:03 AM
93 GA clunking noise from right front when going over bumps scor440 Grand AM 2 09-09-2004 03:59 PM
5th gear drops to neutral when going over bumps FelixF Car Buying Q&A 0 12-17-2003 02:07 PM
