Old 09-07-2004, 09:27 AM
scor440 scor440 is offline
93 GA clunking noise from right front when going over bumps
I have replaced struts, bearing plates,wheel bearings,a arm bushings, stabilizer bar bushings[the ones that have the long bolt and go from a arm to bar end]and brake pads. I have not replaced the rubber mounts that go around the front sway-stabilizer bar yet. Can someone come up with a fix. It only does this noise from the right front. Had it looked at three time and they all say strut bearing plate but it did this before i had new ones put on. Thanks for any help.
Old 09-08-2004, 11:55 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 93 GA clunking noise from right front when going over bumps
check the lower ball joint on that side
Old 09-09-2004, 03:59 PM
jvmrn jvmrn is offline
Send a message via MSN to jvmrn
hey you could also check the tie rod on that side. also make sure that the the strut nut that goes through the bearing plate is tight mine was not tight and it made thumping noises only on that side
