Old 04-03-2002, 05:55 PM
clatescivicr clatescivicr is offline
H22A Accords?
Hey guys, I was wondering who had H22a accords here, and how do they like them? Also what kind of 1/4 times have you been pulling? Thanks inadvance!
Clate - I'm back
Old 04-04-2002, 10:53 AM
super 96 accord's Avatar
super 96 accord super 96 accord is offline
I'll let ya know in a couple weeks
My engine is on order and will be in my car very soon
Old 04-04-2002, 11:10 AM
Do you have any estimates or expected times with the h22a in your accord? Also is it even worth it in the 98+ accords. I saw a weight chart of the cars and the 98+ accords weigh more than the 97+ Preludes Thanks inadvance...
Clate - I'm back
Old 04-04-2002, 11:28 AM
Well right from the get go, I'm putting in a lightened flywheel, ACT heavy duty (95%) clutch, adjustable cam gears, underdrive pulleys, 9:1 pistons, springs, retainers, rods, sleeves. I think that's it for now. The plans are eventually to go turbo on it where I should be making about 350HP to the wheels at least. I'm hoping for at least 12's.
I don't know anything about the newer accords so I don't know if a prelude engine would be worth it. I have the crappy 4cyl non-vtec accord engine so it's definitely worth it for me.
Old 04-07-2002, 12:37 AM
CD6_SiR CD6_SiR is offline
Send a message via ICQ to CD6_SiR
I have the real JDM Accord SiR and it came with a H22A DOHC VTEC engine. Compared to the SOHC and SOHC VTEC Accords, it certainly is more powerful. The H22A is worth it.
My SiR also has a larger 15" front brake disc and 14" rear brake disc. Stabilizer bars are upsized, damper and spring settings are harder, body structure is strengthened. All these are exclusive to the SiR.
So if you do swap a H22A into your Accord SOHC or SOHC VTEC, larger front brake discs are worth considering for the extra stopping power.
Don't know how much it timed since I never bothered to.
Old 04-07-2002, 11:09 PM
5speedaccord 5speedaccord is offline
Send a message via AIM to 5speedaccord
how much did the swap itself cost with out all the add on's your doing to it. i have a 96 ex accord. what would i prob end up paying after i bought the engine and had tinstalled and got everything i need to make it compatale in my car???
Old 04-07-2002, 11:38 PM
Didn't cost me anything, since it's not a swap.
All I did was to spend some money and buy the real SiR.
The H22A just came with the car when it was built and assembled at the Honda plant in Japan.
This is why I said it's the real JDM Accord SiR.
Old 04-07-2002, 11:40 PM
By the way, all the bigger size brakes, stabilizer bars and harder suspension setting are all stock, exclusive to the real JDM Accord SiR.
I didn't swap them either. Just stock stuff.
Old 04-07-2002, 11:57 PM
well how much would it prob run for me to swap??? i have 96 accord v-tec right now. i've found h22a's for sale w/ low milage on ww.thepartstrader.com for around 1500. what else would i need and how much would an instal cost? would i need new wiring stuff and a nw clch etc.... and how much ould that all cost together.?
Old 04-08-2002, 02:41 AM
Sorry I haven't responded sooner but I was stuck at crappy import auto vibe.
If you're interested in doing the swap and keeping your car legal, that $1500 H22A you're talking about won't work. I can almost guarantee you that's for an OBDI engine. If you do an engine swap, you cannot put an engine in your car that's older than your car, so you need at least a 96 engine, which are OBDII and a bit more money. You shouldn't pay more than $1300 for the install. I would recommend at least getting a lightened flywheel installed while the engine and transmission are out though. I got a Fidanza one for 325 and it only weighs 8.2Lbs!! You probably won't need a new clutch but if you're planning on making lots of power later on you should put in the new clutch now since the install will be a lot less while the engine is out, which is why I mentioned the flywheel too. The engine you buy should come with everything you need, the new ECU, axles, tranny, all the wiring. If it doesn't then your installer will be able to do it for you.
Old 04-14-2002, 08:32 PM
smufguy smufguy is offline
Send a message via AIM to smufguy Send a message via Yahoo to smufguy
got any pics of your sir? would love to see them. thanks
member since Jan 2002. working on my Efi conversion and some body work in the front. after that some performance in the future.
1What does it mean when a 1993 Honda Accord needs an service tune up? tools951 Accord/TSX/Accord Hybrid 1 02-12-2011 01:06 PM
H22A Accord H22A1Accrd Accord/TSX/Accord Hybrid 7 09-04-2003 09:24 PM
for sale or trade...1990 h22a accord lx fizzbob7 Cars/Parts for Sale/Exchange 0 05-15-2003 10:02 PM
h22a accord? tenzoracerevovii Engineering/ Technical 4 03-08-2002 12:54 PM
