Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Cosmetics
Cosmetics interior, exterior, wheels.
Old 07-05-2001, 06:22 PM
jcl603's Avatar
jcl603 jcl603 is offline
Send a message via AIM to jcl603
foglight bulbs...
I just changed my foglight bulbs with Eurolite Xenon bulbs. Has anyone heard of them? Are they supposed to be good? Hope they are. Anyways, it was a PAIN IN THE BUTT to put these things in. The square notch was too small to fit. So I tried to cut the square cut-out bigger with wire cutters, it was annoying! I accidently touched the bulbs for a split second while trying to cut a bigger notch, is that okay? Will it greatly reduce the life of the bulb? I know if you touch the bulb, it will reduce the life, but even if it's for a little bit? Also, since I wasn't able to perfectly fit the bulb into the socket, it went in kind of sideways, and is not sitting completely flush with the casing (it's crooked (spelling?)), is that okay?
I put in 55 watt bulbs because I don't think anyone makes 35 watt H3s, and asked the guys that worked there if 55s were okay for a 35 harness. They said that bulbs like PIAA that are 55 watt but work like 85 watt may melt the harness but bulbs that are 55 watt, and operate like 55 watt will be okay. Is that true? Thanks!
The bulbs I put in are very blueish white. I have PIAA Platinums for my headlights and now compared to the foglights, they look like the stock yellow bulbs!!! AAHH!! Looks like I might have to change my headlight bulbs...
Sorry about the long post...
John :apoke:
titanium 2000 g20t
Old 07-05-2001, 09:09 PM
kenchan's Avatar
kenchan kenchan is offline
hummmm... I don't know about the oil from your fingers, but PIAA says 55w, they usually are a little more than 55w. My buddy used 55w PIAA's on his honda and the fuse burned out. the circuit was made for 55w bulbs.
Old 07-06-2001, 03:36 AM
ales's Avatar
ales ales is offline
Forza Schumacher
Just clean the bulbs with alcohol... like pure spirit
98 Aurora Foglight Bulb Replacement Genopsyde Aurora 16 11-21-2004 08:14 AM
1995 Foglight Bulbs MStout 1st Gen 95-99 1 04-20-2004 08:36 PM
Are there HID foglight bulbs for 04 Corolla S? DoriAltis Corolla/Matrix/Voltz 1 01-29-2004 05:34 PM
Foglights bulb for 2001? TT03Z C/K 1 02-11-2003 09:22 AM
Foglight Bulbs MAXIMA PRINCESS Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 07-16-2002 02:26 PM
