Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 03-26-2002, 04:25 PM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
they've finally arrived...
Tein Type HA, 460lbs front, 380lbs rear. these should fix all of my suspension problems for the most part
going on my Preldue tonight.
Old 03-26-2002, 08:10 PM
nittanys1's Avatar
nittanys1 nittanys1 is offline
Send a message via AIM to nittanys1
nice...post some before/after pics....
Old 03-26-2002, 08:43 PM
Me I aM cOoL Me I aM cOoL is offline
Send a message via AIM to Me I aM cOoL
Sweet! Post link to where you got them. I want to check these things out. Also, what kind of camber correction kit are you going to use? This is the only thing that screwed up the suspension on my last car. Give me some input oh master of the Preludes. Inquiring minds must know. I likes de coo green color mane!
Alan
P.S.- Has anyone else noticed that there are about 50 billion of these smiley things that we never use?
:grey: WTF!?! or :alien2: When the hell do you use those?
You think your having a crappy day? Turn to the book of Job and see what that sombitch had to go through.
AOL IS THE DEVIL!!
Old 03-26-2002, 09:53 PM
clatescivicr clatescivicr is offline
I've heard that the Tein's have a rusting problem. Had you heard about this drift? Or do live in an area where that wouldn't be a problem...thanks and would love to hear your feedback on them
Clate - I'm back
Old 03-26-2002, 11:22 PM
drift's Avatar
i just installed them and set them at 12 in the front, and 16 in the rear. i also removed the front sway bar as i broke both of the endlinks.
**be careful with plastic Prelude endlinks!!**
so far i have them set at stock height until the springs settle, tho i will probably lower it a half inch tomorrow and keep it there til it's settled and determine what to do from there. once settled, i'll corner weight it.
as for the rusting, i have heard of it, but am not too concerned. aint nothing a powdercoating can't fix.
shouldnt become a problem since i'm not gonna be raising and lowering the perches once i get the settings right.
as for a camber kit, i'm not slamming it. since it will be set up for racing, the slightly increased camber should help me keep more contact patch on the ground thru the turns.
Old 03-27-2002, 01:07 AM
Beyond Imagination's Avatar
Beyond Imagination Beyond Imagination is offline
Nice! Looks like my Type SS which I just got a couple days ago!
88 Honda CRX Si - B16
90 Honda CRX Si - B20VTEC
Old 03-27-2002, 10:06 AM
drift's Avatar
i opted for the HA's due to more adjustment, helper springs, higher spring rates, higher dampening levels, and rebuildability
Old 03-27-2002, 11:57 AM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
I'm currently saving for som "SS" Teins. Once you get them on (or if you already have them on) let me know how they ride, and how you like the feel of them and what noot. And also how they ride compared to stock. Thanks.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 03-27-2002, 07:59 PM
drift's Avatar
the HA's are very stiff compared to stock. you can view your spring rates at www.tein.com
mine are like 670psi front, 450psi rear. the frotn sway bar is out and probably wont be going back in as it would make the front too stiff for cornering.
at the lowest setting, the ride is still stiffer than stock. as for the SS's, the spring rates are significantly lower than the HA's. for the Prelude, the SS's front springs are the same as the HA's rear springs, and the rear SS springs are even lower. this, combined with a low setting will probably result in a stock-like feel. as for the HA's, there's no way to get a stock feel back in my ride.
corners are flat, with little roll at the lowest setting, and very little roll at the highest setting. front end doesnt dip during hard braking at the highest setting, and no tip up during acceleration. it feels like a little red wagon.
the rear springs tend to clunk over sharp bumps in the road, but may not once the springs settle and the helper springs get a chance to relax a bit. at stock height, my helper springs are fully compressed. more than likely, it'll clunk more... but i dont mind it.
so, speaking from the HA's, i definitely like them a lot. i'll be lowering the car tonight. with little movement, it shouldnt rub the fenders.
also, the struts are shortened piston. taking out the old struts may be a bit painful, but putting in the Teins was a snap.
Old 03-28-2002, 04:03 PM
1993HondaCivic 1993HondaCivic is offline
i envy you
Old 03-28-2002, 04:41 PM
I was told that SS is supposed to have a ride close to HA's ... If I knew there was only a slight difference in price from SS to HA then I would have gotten the HA's but since I have SS, guess I'll have to live with it ...
Old 03-28-2002, 04:46 PM
I've been riding on Skunk2 coilovers for quite a while so I don't remember what stock feels like ... But I'll never forget the way I fly out of my seat for every big bump I hit with these Skunks ... I'm sure I'll love these Teins ..
Old 04-01-2002, 08:15 PM
Dezoris Dezoris is offline
Mod for life
Send a message via AIM to Dezoris
jesus christ those front spring rates are really high, I could not stand that where I live!
Also, i wondered why you were talking about springs settling? Those springs should not settle for over a year? Do they not pre-set them in production?
Actually how are those springs not progressive? with the two spring sets with different size coils?
M.Sanew - AutomotiveArticles.com
Old 04-01-2002, 11:25 PM
drift's Avatar
the front spring rates are very high, but the struts were valved to control them properly. considering the FWD and motor weight, they provide better front end support without nose-diving, and proper weight balance on the front corners due to lack of nose dive. i removed my front strut bar since i ended up breaking the links anyways, and would recommend tossing the sway bar for this setup.
as for settling, the springs, as far as i have dealt with Tein, they dont preload the springs during manufacture. they will settle with time.
the springs arent progressive. they are a consistant wound coil. the helper springs on the other hand provide no progressiveness tot he spring tension. they merely expand on full extension to keep the spring in the upper mount and prevent "clunking".
Old 04-01-2002, 11:33 PM
Cali Guy
Thanks for the info on the HA's Drift, I'm curious as to the feel of the SS's but it's good to know about the HA's as well, since they are only a little bit more $$$. What exactly is the purpose of the helper springs? Is it for added support, or dampening? And can the SS be ordered to custom spring rates like your HA's were? All I want, is a GOOD quality stock like ride, that I can push to limits the stock suspension would never be able to handle, and also a ride I can adjust per driving situations I might be in, such as cruising with friends, then coming up on a maountain road, pulling over and adjusting the ride to the stiffer setting, and then adjusting it back soft when back on the freeways and/or roads. I don't need a road racing competant setup, just something that'll handle occasional mountain type driving. This is why I'm opting for the SS over the HA. That, and the SS are very well priced for what they offer, and their reputation.
hessemer69 on AIM
It finally arrived! Mardam Car Modeling 5 03-07-2008 02:04 AM
The day is finally arriving! Tony '88 - '91 Civic | CRX | Wagon | Shuttlee 23 09-14-2007 11:52 PM
Finally arrived and rearing to go!! Sean King Introductions 2 02-11-2006 09:42 AM
Well it finally arrived rallying83 Car Modeling 5 07-26-2005 07:38 AM
My little princess finally arrived..... babyskyline Sentra | 200SX (USDM FWD) 16 11-26-2002 11:12 PM
