Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 03-24-2002, 11:06 PM
AWD Primera's Avatar
AWD Primera AWD Primera is offline
Installing New Spark Plugs
Can anyone help me. I need to know how hard to tighten my new spark plugs. Im afraid that if I over tighten them I might end up making the gap to small?
Help appreciated
Old 03-25-2002, 03:57 PM
redvalkrie's Avatar
redvalkrie redvalkrie is offline
Send a message via Yahoo to redvalkrie
Red face Read the box!
There is a certain torque range you must follow, do not over tighten you won't mess up your gaping but you will "F" up your threads then you are screwed.
What I do is wait for engine to be cold very cold not luke warm, do you thing to do tune up.
When tighten it when you start feeling resistance tighten it up very gently like a little biatch don't over tighten you will f up the threads & will need to re-thread or replace valve cover.
(I hear what you are saying but I feel you are lieing to me, would love to say to BUSH!)
"Don't trip, skip, pinch your forehead"!
1988 CRX Si
2001 CBR 600F4i Silver & black FAST!
2004 Toyota Tundra (TRD)
2002 dodge grand caravan.
Old 04-01-2002, 09:07 AM
ronnie_g's Avatar
ronnie_g ronnie_g is offline
Yeah! Do not over thighten it for the reason of it might get loose somehow. I used to tighten my plugs too much before and broke the ceramic body. Lucky enough that I was able to remove them. My old pal(senior citizen retired mechanic who works for BMW) gave me a lesson not to tighten my plugs anymore. So, take it easy! Tighten it and feel as if you could remove it without too much force. Better yet is to get yourself a torque wrench and follow the torque specification on the manual. Good Luck!
94'G20t / UR Ultra S pulley / JWT Pop charger .....
Sony ES Head/Boston Acoustic Pro Series 6.4/ Cerwin Vega 6002/
MTX 3x10's/ Monster Cap
Sony XE-90MkII EQ/ SonyCDX715
CD Changer/Nakamichi EC-302
Mobile 3-Way Electronic X-over
Amps: Fosgate Punch 600w A4/ Kenwood PS300/JBL GTQ360
Protection: G19 15+1 Cor Bon +P 115 GR JHP/Bali
:jump: :badass:
Old 04-03-2002, 02:35 AM
Yahnozha Yahnozha is offline
Send a message via Yahoo to Yahnozha
Speaking of spark plugs, Im changing mine this friday and was wondering what the gap is supposed to be set to? Thanks.
P@ - www.customsteel.com
Red 99 G20(t) / UR 2 piece / JWT POP / HS CAI / WW Lip / HS Header / Greddy Evo / S3 cams
Old 04-03-2002, 06:49 AM
NismoPC's Avatar
NismoPC NismoPC is offline
Depends on which ones you purchased. Anything other than NGK, can't help you out. Hopefully, you stuck with NGK's.
PFRB6-11 Platinum >>>> 0.039-0.044 (get as close to 0.044)
BKR6E Copper >>>>>>> 0.031-0.035 (get as close to 0.035)
Brandon
'96 G20 - modified
Old 04-03-2002, 07:30 AM
ronnie_g's Avatar
Hey Yahnozha! What's up! I noticed that you have JWT POP & HS CAI?
How does it work? Do you use both or you converted your POP into CAI?
I got the JWT POP & I want to convert it into CAI. Please let me know how, where I could get the convertion kit, how much I could spend, and if I could do it on my G20t 94'.
Thanks!
:jump: :badass:
Old 04-03-2002, 07:36 AM
ronnie_g's Avatar
Oh yeah? Does anyone of you use Bosch 2 or 4? I use Bosch 2 and I don't freakin' know what the hell is the feel difference from regular NGK Platinum. Would it make a difference if I use Bosch 4? What about Bosch Gold Tip? (Just kidding folks :hehehe: )
:jump: :badass:
Old 04-03-2002, 07:46 AM
NismoPC's Avatar
Stick with the NGK's! They are the best for the SR20's. It's been proven time and time again.
The only other plugs I've heard positively about are the Denso Iridiums, but not many are running them because they are pricier than the Platinum NGK's.
Don't waste time, money effort on the Bosch 4. Go buy a set of PFRB6-11's and call it a day. Or you can opt for the cheaper NGK V-Power Copper BKR6E's. They are a hell of lot cheaper, but they need replaced in half the time as the plats.
Brandon
'96 G20 - modified
Old 04-03-2002, 09:42 AM
FlossinPrimera FlossinPrimera is offline
Send a message via ICQ to FlossinPrimera Send a message via AIM to FlossinPrimera Send a message via Yahoo to FlossinPrimera
Densos are about 20$ a peice.
1994 Infiniti G20 5 speed (rebadged as Nissan Primera)
K&N, Enkei Type 11 GML, JVC KD-SH55 Digifine, Pioneer Pear-mica components, 2 12" round things that bang and a 400W amp to make them bang. Coming soon: ACT clutch, new half-shafts, HKS superform springs, KYB AGX adjustable shocks, $tillen STB, 17" König Toxxins with Yokohama Parada Tires (P215/40R17).
http://gforces.streetracing.org/
"I wish Captian Archer was as much as a racial bigot as Captain Kirk"
-Burt Weed
Old 04-03-2002, 11:49 AM
I sticking with stock plugs...
Hey Yahnozha! What's up! I noticed that you have JWT POP & HS CAI?How does it work? Do you use both or you converted your POP into CAI?I got the JWT POP & I want to convert it into CAI. Please let me know how, where I could get the convertion kit, how much I could spend, and if I could do it on my G20t 94'. Thanks!
Actually the CAI term is really a mis-nomer. What I bought is the first sectoin of pipe that goes between the throttle valve and MAF. I havent installed that part yet because I have to find time to make an adapter to fit over the MAF to connect to the 3" pipe. OR just find a silicone sleve that tapers from 3" to what ever the diameter of the MAF is. I've been too lazy to do it yet.
Although, there is an adapter piece to fit a JWT POP to the whole CAI system that HS offers. I dont know if anyone has done it because *I think* the JWT POP is kinda large for the area that it goes into in the wheel well. I coud be wrong tho...try it, Im sure others will follow if it works...
Old 04-03-2002, 04:10 PM
ronnie_g's Avatar
:cyclops: Oh sh#t yeah! I'll stick with NGK too.
Thanks Nis :ylsuper
:jump: :badass:
Old 04-04-2002, 02:16 AM
A380Driver A380Driver is offline
Send a message via AIM to A380Driver
You *NEED* a torque wrench. Its important so that the plug is at the right torque to make sure it will take the heat away from the cylinders. It also makes sure that the plug is in the correct position.
I suggest reading NGK's website on this, they have some great information.
One neat thing that I saw was that some racing engines actually use washers and set it up so the plug is facing a specific way in the cylinder for maximum effectiveness...wow
-Brian Jones
I got a snake man
Old 04-04-2002, 05:10 PM
ronnie_g's Avatar
Hey 380! Why did you mention about NGK's website? I just visited it and found more info. Now I'm more
Darn it :cry: :jump: now what should I do? :eshooter:
:jump: :badass:
Old 04-09-2002, 12:51 AM
If you havent changed your plugs yet (which you probably already did) torque them down to 25-32 ft-lbs. And buy a good torque wrench. Do a search at www.craftsman.com for them. Youll want the click type that dials in with the correct setting.
E150 5.4L Spark Plug Replacement leroge Econoline 1 04-19-2010 08:19 PM
spark plug analysis keilerstag Cutlass Series 1 06-29-2009 08:25 AM
spark plugs freakyfire05 ZX2 2 02-17-2009 11:03 AM
New spark plugs without new wireset? Stuffy Rodeo | Passport | MU 5 09-16-2007 05:08 PM
Installing new spark plugs in '03 Montana sircarlton Montana/Montana SV6 2 12-12-2006 10:55 AM
