New spark plugs without new wireset?
Is it no good to just change the spark plugs rather than changing the spark plugs as well as the wireset? One's cheap, one's not. If you don't know already, you can guess which.
Also, has anyone heard of the Technical Service Bulletin for the 93 Rodeo V6 4x2 automatic about oil leaking into the spark plug tubes, and an upgraded wireset being required for some reason? Tell me what you know? Thanks! |
Re: New spark plugs without new wireset?
If the wires have over 75k I would change the wires too.
-Ryan Isuzu Moderator Car Show Tips Operations manager with a results-driven passion for process improvement FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd |
when you install them, coat the inside with dielectric grease, and put some antiseize on the *outside* so it will be possible to get them off later (this last tip from JLEMOND isuzu xpert.). also make very sure when you install them that they are fully seated onto the plug, it can be difficult to tell sometimes. good luck //bc
1992 trooper 3.2L v6 sohc automatic...as is i love a good intermittent electrical challenge. . .especially when it's someone else's. |
//bc
Borg Warner also makes the upgraded set. Available from Parts America for less than 40 bones.
