Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 03-24-2002, 07:46 PM
XeUz XeUz is offline
Send a message via AIM to XeUz
Question Aem Intake Install
I was just wondering if the install for the AEM intake was difficult for the Spec V's. What do you do with all the sensors? How much power will it add?
THANKS,
XeUz
Old 03-25-2002, 09:24 AM
Sentra Styling Sentra Styling is offline
Send a message via AIM to Sentra Styling
Putting in a CAI is really easy and straight forward....But as far as all the the sensors (2 of them) are still being used...one sensor is on the MAF which stays connected and is used and the other plugs right into the bottom tube...
The intake consists of
3 rubber sleeves
2 pipes
1 filter
and roughly 7 clamps
but it'll assembly in this order from throttle body out.
Rubber sleeve
1st pipe
rubber sleeve
MAF
rubber sleeve
second tube
filter....
I hope this helps....If you need to see apic let me know and I'll provide one for ya...
2002 Nissan Xterra SE Black
1993 Sentra SE-R Black
1994 Sentra SE-R Red
All SR20DE powered...
Old 03-25-2002, 10:17 PM
TopSpin RayGe TopSpin RayGe is offline
Send a message via AIM to TopSpin RayGe
isn't it MAF then MAF adaptor? or is that implied?
btw, make sure you plug in all the sensors before you start your car, or you get the dreaded check engine light.
gene, the boards look completely wiped out tonight. but tomorrow's the 10th day for mine, so hopefully mine will go out (like it did for serge).
installed AEM intake, check injen light..... 0specv3 Sentra | 200SX (USDM FWD) 3 12-22-2003 07:50 AM
Problem removing resonator box during AEM Cold Air Intake Install...need advice Arkham Accord/TSX/Accord Hybrid 2 11-24-2003 10:53 AM
AEM V2 intake installation bmark3 Engineering/ Technical 0 09-05-2003 10:56 AM
2000 honda civic AEM short ram intake installation special_k188 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 7 02-20-2003 07:24 PM
AEM intake install help... THE4TH '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 09-14-2002 08:32 PM
