Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 12-13-2003, 07:16 PM
0specv3 0specv3 is offline
Send a message via AIM to 0specv3 Send a message via MSN to 0specv3 Send a message via Yahoo to 0specv3
Angry installed AEM intake, check injen light.....
my check injen light wont go off after i installed an AEM intake. i would bet i installed correctly, and it is running great. does anyone hoave any suggestions?
Old 12-13-2003, 10:58 PM
DaxManio's Avatar
DaxManio DaxManio is offline
Did you put it all back correctly? Sounds like somethings wrong with your MAF sensor..
Check out www.sentra.net and www.nissanforums on how to turn off that light
Old 12-19-2003, 07:07 PM
mreff mreff is offline
Re: installed AEM intake, check injen light.....
Well, assuming you plugged the MAP/MAF in.
you just need to reset the computer. Unplug the negative side of the battery for a few minutes.
Old 12-22-2003, 07:50 AM
mtorsani mtorsani is offline
Send a message via AIM to mtorsani
You should have removed the battery anyway when installing the AEM intake. When I installed mine, my SES light came on for about a day. It just takes some time for the ECU to recognize more airflow is coming in. If it is on for longer than a few days I would double check you installed everything correctly. Any other questions...search for answers on www.b15sentra.net
Proud Member of PI-Motorsports
2002 Molten Silver Nissan Sentra SE-R Spec V
35,000 Miles **Pre-cat recall done**
AEM, Mobil 1 5w-30, AC Autotechnic Reverse Indiglo Gauges, Sparco Grip Pedals
***Courtesy of Grafxwerks: "Spec V" Third Brake Light Overlay, Reflective Dark Red Wheel Inlays, Dark Red Reflective Spec-V Door Stickers
