Old 03-22-2002, 12:37 AM
Thing-A-Majig Thing-A-Majig is offline
were do you get your big brakes?
i was thinking of getting a set of brakes like the ones on guiddy's r 34 ad pmans beetle, but ive searched high and low for those on hlj, but i found nothing. do you guys happen to know where i can get a set?
Old 03-22-2002, 02:04 AM
Jay! Jay! is offline
Horizontally Opposed
Some of the older Fujimi wheel sets came with them, but I'm not sure which. Phil would know...
Also keep in mind that for each kit Pman and Guiddy have done, they probably have another they've canabalized for parts.... I don't know how many of Warren's cars have those same 15-spoke wheels...
Hierarchy of Subaru:
(Click to see mine!)
Old 03-22-2002, 02:30 AM
Guiddy's Avatar
Guiddy Guiddy is offline
The big brakes on my R34 came from the Tamiya Volvo 850BTCC, and I have many other kits in the spares box which can supply similar parts.
It's the price you have to pay for customising kits.
Old 03-22-2002, 05:22 AM
primera man's Avatar
"P-Man"
Same as Dan....most are spares apart from the VW.
The rims are OZ RACING and the brakes came in the kit.
View All My Models Here.
Old 03-22-2002, 05:12 PM
hirofkd's Avatar
hirofkd hirofkd is offline
Check Fujimi Wheel/Tire set in HLJ. Those sets priced at 700 yen usually come with large drilled disks, molded with the caliper. Read their product descriptions to make it sure.
Hiroaki Fukuda
Old 03-22-2002, 05:39 PM
mediamixhobby mediamixhobby is offline
Re: were do you get your big brakes?
Take a look at my shop and you'll find plenty of wheels and brake disk for WRC cars which wll be suitable. URL is in my signature.
cheers,
Wong
MediaMix Hobby
http://www.mediamixhobby.com.sg
Old 03-22-2002, 07:53 PM
thanks guys, i was hoping to get a less expensive solution .
hiro, thanks ill keep looking around on hlj
media mix, ive looked on yor site but didnt find anye bake discs al i saw were those upgade kts that had little foilf stickers that go ontop of the disk brakes
Old 03-23-2002, 01:01 AM
How about this:
Details here:
http://asiapac.worldpay.com/cnb/shop...duct_info-null
MediaMix Hobby
Old 03-23-2002, 01:45 AM
thanks media mix i guess i was looking in the wrong area for it when i used the search, i made the mistake of ressing enter instead of clicking go so i as brought back to the home page, so that led me to believe there werent any brake disks available.
thanks, this sure does beat buying awhole new kit just for the brakes
Old 03-23-2002, 01:20 PM
pkw1's Avatar
pkw1 pkw1 is offline
sorry for the late reply.
ya, I get a lot of my brakes from swapping from kits to kits.. Fujimi's line of Just tunning usually comes with large Brembo brakes, each kit comes with 4... but rarely do they use such big brakes at the back of cars, so what I usually do is use the kit's front brakes for the back, then use the brembo's up front... so each kit has enough brakes for 2 cars
Studio27 (can be bought in HLJ) has a very nice of metal rotatable calipers/rotors set... but it ONLY costs more then most model kits out there *rolleyes*
I also buy Tamiya rally/touring cars which I find in hobby shops for DEAD cheap because of missing/damaged parts, and use those as parts kits. I got a Ford Essort WRC by Tamiya for like $5US :smoker2:
All projects stalled...
Need to settle in on my new job, and don't have time to built models just yet.
Old 03-23-2002, 05:22 PM
Murco's Avatar
Murco Murco is offline
Maximum Car Guy
Send a message via Yahoo to Murco
Forget that plastic junk!! The only option when you want triple-throw-down brakes on your model are photo-etched units from The Model Car Garage or Machined Aluminum Specialties!! The MAS kit even comes with blank rotors so you can drill them, install lug nuts and bolt your wheels on!!!
My AF Classic Model Car Gallery
Old 03-23-2002, 05:28 PM
Originally posted by Murco
...The Model Car Garage...
I was looking at thiers the other day... They like sandwiches so they have the vents around the edge of the disk, right? but then that means that you only get 1 pair in each set? Then what about the calipers, too? All separate, I guess?
Old 03-23-2002, 11:58 PM
Murco's Avatar
Maximum Car Guy
Correct, they can be sandwiched if you wish to remove the wheels for display and it gives them the correct depth and vane detail. If your wheels aren't removeable you can install them flat without using both sides and it still looks great!
As for calipers, Replicas and Miniatures of Maryland sells a terrific line of resin Brembo calipers that are $3.99 per pair or build your own out of layers of sheet styrene (very easy)!!
No, these options aren't the cheapest but they are the ultimate for accurate detail. You can truly trick-out a curbside model with photo-etch for less than $25.00. The real money comes when you trick-out an engine like in my ZL1 Camaro (see AF gallery). The engine alone cost about $75.00 in photo-etch and plating, not to mention the pulleys, distributor base and other parts I machined myself along with my labor. The carburator alone has 16 photo-etch pieces and 2 weeks of time in it.
The question you need to ask yourself is, "How detailed do I want this car to be and what am I willing to do to get it there??"
Old 04-01-2002, 11:42 PM
... or build your own out of layers of sheet styrene (very easy)!!
Could you tell me more about this? I bought a set of 15" disks for my WRX, but the race calipers were a little over the top. I have some spare styrene sheets lying around... What do I do?
Old 05-22-2002, 09:27 PM
sausage sausage is offline
Does Model Car Garage have a website?
How do you get these big boys started after they're warmed up? driverjohnlh Cadillac Classics 2 11-02-2009 10:02 AM
how did you get your hands on your classic chevy? Young Chuck D Chevrolet Classics 2 03-14-2007 02:02 AM
If you could do it all over again, would you get your blazer? zachzchw Blazer 52 11-17-2006 06:53 AM
where do you get your money? thomas crown Accord/TSX/Accord Hybrid 13 03-08-2002 03:51 AM
