Old 03-20-2002, 12:03 AM
asnrefugee asnrefugee is offline
Send a message via AIM to asnrefugee
2.25 inch vs 2.5 inch custom piping.
I heard that 2.25 inch piping gives more low-end power.
and 2.5 gives more high-end power.
Is this true?
Is there much of a difference?
I also have a stock catalytic converter. What size diameter does it have?
When I do the custom piping should i change the catalytic converter?
Old 03-20-2002, 11:06 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
the 2.25" piping is ideal for most hondas/acuras becuase they rely on back-pressure to work correctly, when you step up to 2.5" or bigger that is usually for Forced induction cars, becuase they have more power and more gases to exit from the combustion chamber. 2.25" is the highest a normally apspirated car should have on it, to gain the most power with minimal loss overall(did that make sense?).
As far as the cat goes, it is prolly around 1.5 - 2.0" range and for max performance out of your exhuast it should be replaced by a high flow unit to fit the rest of the new pipe work. There are notcible gains from installing a new exhuast system expect about a 7-10hp increase at the wheels with the installation of the new highflow cat and exhuast system.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 03-20-2002, 12:44 PM
SRHguru SRHguru is offline
Send a message via AIM to SRHguru
Yeah, unless you have FI do not go larger than 2.25, and if you are getting it custom dome, make sure they use mandrel bent stainless steal piping. As far as the cat, make sure you get a smog legal high Flow Cat if you wanna pass emmissions/carb tesing or whatever it is where you are from.
95 civ ex
Mods-
Thermal R&D catback.
DC sports short shifter
Iceman CAI
Centerforce clutch
Nuespeed spark wires
Yellow dash inserts
16" Rota Wheels w/ yoko rubber.
Old 03-20-2002, 04:39 PM
hondajigga hondajigga is offline
Send a message via AIM to hondajigga
If you know how to turn a wrench and don't mind getting dirty once a year I would say get a test pipe and when emissions rolls around swap you stock cat back on. Get the test pipe to fit your model car so its the same size as your stock cat and have your exhaust guy build from there. Even the free flowing cats have problem passing emissions(becasue they can't make up for a bad tuned car the way a stock cat can). This way you can save yourself some $$ on those expensive free flow cats and the test pipe will yeild more HP. Also if you are getting a custom set-up i would look into an adjustable muffler.
and mandrel bent is the only way to go(stainless is dependant on you budget)
good look man
Old 03-20-2002, 06:36 PM
So I should get race cat?
Will people off the streets know i have a racing cat?
Or do you have to go underneath to find out?
Does it make a louder noise?
I heard that someone put on a race cat and when he got out of his car he can smell gas fumes.
How much more is stainless steel?
Old 03-20-2002, 10:48 PM
jOYRiDe jOYRiDe is offline
stick with the stock cat, since your car is still relatively new and also high flow cats are very expensive.
cats shouldnt make it any louder, its the exhaust tip and they shouldnt be making the car smell like gas either.
u cant tell a high flow cat from a stock cat, they usually look alike.
listen to the other guys, use 2.25inch mandrel bend stainless steel. it is more expensive but its worth it.
stainless steel lasts upto 10 years whereas mild steel lasts upto 5 years.
Old 03-20-2002, 11:01 PM
Fair priced enough to be worth it. You do not want that shit to all rust up and all. IMO anyways.
95 civ ex
Mods-
Iceman CAI
Centerforce clutch
Yellow dash inserts
Old 03-21-2002, 04:43 AM
MARKUSIUDIUS MARKUSIUDIUS is offline
Wow
The low down to the first question.
A bigger exhaust does give more top end and smaller exhaust bottom end (but not to small). A longer intake is good for bottom end and short intakes for top end.
If you have extractors on your car the exhaust has to be of size not to big so that the pulsation of the gases is kept in motion through the extractors other wise a to bigger exhaust system can actually repead the gases the extractors are attempting to flow.
Good sizes (average) 1.0lt - 1.6 1.75 inch for 1.6 - 1.8lt 2 inch, 2.0lt - 2.3lt 2.25 inch for 2.2lt vtec engines 2.25 or 2.5 inch.
Madrel bends YES. Stainless??? All mufflers, cats etc in stainless but the piping will last ten years easy in mild steel even longer with a high temp coating.
All the best:flash:
1994 2.2lt Jap import Vtec, Blown with a 1GGZE charger 300Hp or 220+kw
Malpassi Reg, 500 injector, Unichip piggyback management system, Top gun leads, Map controller, Vtec controller, Custom FM Cooler, Custom fast flow exhaust and weight reduced (2640pds)
Old 03-22-2002, 07:42 PM
What is the orignal size of the factory piping?
Old 03-22-2002, 11:01 PM
somewhere between 1.75 in to 2.25 inch most probably
Old 03-25-2002, 01:33 AM
Tape
Grab out a tape measurer or ruler and find out.
But on your car I'd say its either 1.5 or 1.75inch depends if its vtec or not.
If its not go for 2inch and if it is go for 2 or 2.25 inch.
:flash:
Old 03-25-2002, 03:04 AM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
So if I have a D16Y7 (Civic DX) motor, then I should go with the "2 inch piping, verses the "typical" "2.25 piping? Remember, 1.6l NON VTEC here.
MARKUSIUDIUS: when you said a longer intake is good for low end, and a shorter for high end, did you mean a Cold Air intake is better for low end increase and a short ram intake is better for high end increase? That was something I never new if that is what you meant.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 03-27-2002, 02:41 AM
Yes
On a 1.6lt motor a good 2 inch system will flow just as much as 2.1/4 inch and without the noise.
Long intake is yes, better for bottom end and a shorter for top end.
Within reason.
A filter under the factory airboxwill give better bottom end then one at the throttle face, but will loose in the top end stakes.
Its much like short and long intake runners.
Before I installed my blower I used to have twin throttle bodie set up. It was a second throttle face tapped into the rear of the factory throttle bodie to come on at different adjusted times. The first one had the standard intake piping with a pod filter on the end and the second had a filter right at the throttle mouth. As you accelerated the first would open for bottom end and at about 2/3 of full throttle the second would snap on for top end power.
On the dyno the top end power was only about 5hp at the wheels more than with the standard throttle and pod setup but it had a better power curve from start to finish. It with only a few other mods was good for constant mid to high 14s.
But then I seen the light.
:flash:
2001 2.0 Jetta with 5 codes???? moemo '97 - '03 1 12-29-2009 05:22 PM
Difference between 2.25 and 2.5? xchrischrosx Off-Topic 8 07-03-2005 04:19 AM
2.25 or 2.5 in. exhaust RedRex16 '88 - '91 Civic | CRX | Wagon | Shuttlee 4 08-18-2004 07:33 AM
2.5 inch pipe with exhaust... Do or Don't? ERIKbronx Engine 14 04-19-2002 12:34 PM
