Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 03-14-2002, 07:41 PM
BoosterSH's Avatar
BoosterSH BoosterSH is offline
Is this set-up a good mix?
Ok. I have the set-up below planned out for my Prelude and i was wondering if any of you think the set up will work good, or you think i should add/subtract certain things.
My current mods are:
AEM CAI
AEM Power Pulleys
GReddy EVO
DC Ceramic 4-2-1 Header
Ground Control Coilovers
18" Katana C5s on 215/35ZR/18 Nitto 450s
What i want to add:
Crower/Skunk2 Stage2 cams
Crower/Skunk2 Cam Gears
Apex-i VAFC
Jackson Racing Supercharger
Fuel Pump
Fuel Injectors
Clutch/Flywheel
Completely DYNO tunned
My main concern is how well the cams will work with the supercharger. Everything else should come together well. What do you all think?
Old 03-15-2002, 03:34 AM
buh_buh's Avatar
buh_buh buh_buh is offline
Send a message via ICQ to buh_buh
I think you should throw in some aftermarket struts into the mix.
Don't you bounce around a lot without them? How much are you lowered?
AF Nordic Crew #3
Old 03-15-2002, 11:50 AM
BoosterSH's Avatar
I have about a 2.5in drop in the front and 2" drop in the rear. I dont bounce at all. The car still drives smooth and soft. I thought the ride might be bumpy but it actually drives better than stock to me. The gound controls are by far the best lowering mod for the prelude. Im actually adding Koni adjustables soon, forgot to add that to the set up.
Old 03-15-2002, 04:48 PM
fritz_269's Avatar
fritz_269 fritz_269 is offline
I think the Crower 63421T cams and 68184 valve springs would work well for you.
But you should definitely call Jackson Racing and see if they have any specific cam recommendations.
how will this set up PERFORM????!!!!! crabby760 Let's get Technical! 14 12-06-2005 10:05 PM
Is this set up good? IntegraBoy405 Car Audio 14 01-31-2005 11:48 AM
how does this set up look????? highteknology Car Audio 3 08-12-2004 04:33 AM
For the techies! how is this set up Rob80 Forced Induction 27 05-16-2003 07:52 PM
how's this set-up? Darkwing '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 14 03-21-2003 02:15 PM
