Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 12-05-2005, 04:43 PM
crabby760 crabby760 is offline
how will this set up PERFORM????!!!!!
ls block with c5 type r pistons, rings...
new bearings new rods coated,, type r oil pump, micropolished crank
jdm b16a head stock....
with intake/header/exhaust fpr... dyon tuned
any estimated dyno numbers.... ???
having shawn church or eugene "PROSTREET' do tuning
this swap is in a 95 integra ls
Old 12-05-2005, 04:46 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: how will this set up PERFORM????!!!!!
remember with type r pistons, your looking at alike a 12:1 compression
Team Lonely Drivers
Old 12-05-2005, 04:48 PM
12:1 comp with type r pistons and a stock b16 head?
can i run 91 octane?
Old 12-05-2005, 05:26 PM
my calculations show 11:3:1 or 11:5;1 highest... wich is fine right?
Old 12-05-2005, 06:52 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
that's fine...just have to tune accordingly
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 12-05-2005, 08:29 PM
any idea what kind of hp numbers i'd be lookin at?
Old 12-05-2005, 08:44 PM
Schister66's Avatar
AF -Advisor
check your set up against some of the different tuned set ups on www.evans-tuning.com
Old 12-05-2005, 08:45 PM
what site did you get your compression numbers off of?
Team Lonely Drivers
Old 12-05-2005, 08:58 PM
went to yahoo and typed in... b-series compression calculator...
and i tried 2 or 3 of em...
none said 12:1
Old 12-05-2005, 09:00 PM
b18b block with b18c5 integra type r pistons... with stock b16a head
Old 12-05-2005, 09:54 PM
the 2 i used, one said 12.2 and the other said 11.3, but on the second one, i put p30 b16 pistons, and that went higher than the type r pistons so i didnt trust that site. unless p30 pistons yield more compression than the type r pistons.
idk which one to trust, your choice
Team Lonely Drivers
Old 12-06-2005, 12:22 PM
JustaSolVTEC JustaSolVTEC is offline
Send a message via AIM to JustaSolVTEC
Re: Re: how will this set up PERFORM????!!!!!
you should just stop talking now. a B16 head won't bump compression up a full point. his compression would be about 11.1 or 11.2:1. I suggest you start using your brain instead of using a website to calculate compression.
Old 12-06-2005, 04:23 PM
do u think this is a good set up?
ls block with b18c5 type r pistons new rings
81.5 mm
new rods and rod bearings coated...
micropolished crank
type r oil pump
gsr timing belt gsr water pump
b16a jdm stock head with intake/header/exhaust....
after dyno tuning by shawn church or eugene "PROSTREET".... watta u think i should lay down at the wheels... hp an tq...?
Old 12-06-2005, 09:59 PM
ok sorry my bad, my calculations were for civic type r pistons, not integra type r pistons. i got 11.3 with c5 pistons but if you go 81.5mm bore, that would bump it up to 11.4
Team Lonely Drivers
Old 12-06-2005, 10:05 PM
you say new rods, stock rods? aftermarket rods?
also why go 81.5, why not go 81.25. it will save you room for another bore later if you want to rebuild the motor again or someone fucks up putting it together
Team Lonely Drivers
