Old 08-09-2004, 10:42 AM
highteknology's Avatar
highteknology highteknology is offline
Send a message via AIM to highteknology Send a message via MSN to highteknology
how does this set up look?????
now keep in mind i don't want the best system out there. just something that sounds good and will get fairly loud.
currently i have an alpine deck (cda-9827) and 2 12" infinty subz running off a bazooka amp (from older system). here's the specs for my bazooka amp http://www.onlinecarstereo.com/CarAu...roductID=12353. the subs can handle 300 watts rms x 4 ohm. is this amp underpowering the subs?
anyways here is the set up i'm looking at. http://www.techronics.com/index.cfm?...Product_ID=893
they are infinity speakers, alpine amp, and a rockford fosgate cap. i'm planning on wiring the cap to the battery then running the two amps off the cap. will that be good?
help me out here, i would like to get this system set up before i go back to school simply because i won't have that much time when i'm in school and working.
any suggestions as to what to think about. thanx
Old 08-11-2004, 11:26 PM
Harryc8786's Avatar
Harryc8786 Harryc8786 is offline
Send a message via AIM to Harryc8786
Re: how does this set up look?????
Well with your cap it should be as close to your amp as possible, so if you run 2 amps i think your supposed to put the distirbutor on after the cap, keep the cap close to the amps though. Thats what they are made for. I duno what amp your running or the subs that link didnt work.
Old 08-11-2004, 11:46 PM
the amp is a bazooka el2100
Old 08-12-2004, 04:33 AM
empathydude empathydude is offline
Send a message via AIM to empathydude Send a message via Yahoo to empathydude
eww your better off running your subs off the deck
http://members.cardomain.com/empathydude
Put an extra set of neon lights on your car, they make you go faster. =)
