Old 03-14-2002, 07:06 PM
johnny1329 johnny1329 is offline
What is mandrel piping?
I don't know the difference between mandrel piping and regular aluminum piping? Why is it said that mandrel is better. Thanx:bandit:
Old 03-14-2002, 07:13 PM
454Casull 454Casull is offline
First of all, mandrel bending is completely independent of the material being bent. That being said, some materials are more resistant to bending than others.
During mandrel bending, a 'mandrel' is stuck into where the bend is going to be created. It allows the outside of the tube to stretch and the inside of the tube to compress, while keeping the material from crumpling together and 'wrinkling', you could say. Think of a normal straw, and a straw with that bendable neck. Visualize bending both in your mind. Which one of them flows a fluid more easily?
If you didn't infer from that previous paragraph, mandrel bending allows fluids to flow quicker and with less turbulence than with standard crush bending. When this is applied to an exhaust pipe, backpressure is reduced and you'll see some power gain.
EDIT: Damn my grammar is bad tonight...
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
Old 03-14-2002, 07:21 PM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
I'm guessing that you mean "mandrel bent" piping?
The "mandrel" that I'm familiar with is a tool for bending things. "Mandrel bent" is sometimes contrasted to "crush bent" piping; the difference is in the process/tools used to bend the pipe.
From http://www.m-w.com
Mandrel
b : a metal bar that serves as a core around which material (as metal) may be cast, molded, forged, bent, or otherwise shaped
Perhaps this link will be useful to you: http://www.extrememotorsports.com/mandrel.htm
Otherwise, you might try here: http://www.celebritystorm.com/celebs...el/index1.html
hope that helps.
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 03-14-2002, 07:22 PM
looks like we were typing our responses at the same time...
Old 03-14-2002, 07:27 PM
Doesn't matter so long as the information isn't conflicting, right?
Old 03-15-2002, 06:38 AM
Thank you for the information, it really helped.
crush vs. mandrel piping Chiquae07 Non Specific 16 03-25-2007 01:11 AM
replacement muffler...what size pipe? chefordlet C/K 0 01-07-2004 09:35 AM
what diameter pipe for for custom exhaust? xxjustinellisxx Engineering/ Technical 5 08-10-2003 11:38 PM
What Y-Pipe is the best??? funnylittlman Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 6 11-17-2002 07:34 PM
