Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 11-17-2006, 07:27 PM
capriceowns capriceowns is offline
How to measure compression ratio
With my basket case engine I got it came with new rods/pistons with the pistons pressed onto the rods aleready, I figured out there Speed pros by a number on the side.
But it either comes up as a cast aluminum one, or hyperuerutic. both with very dif comp rations.
Is there a way to measure the compression Ill get with these pistons without installing them/etc?
1987 Chevrolet Caprice classic Brougham. 142,000 on the 305 and still chugging
Old 11-17-2006, 07:55 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: How to measure compression ratio
You can measure the volume of the dish, if present, with fluid measured with a graduated cylinder. You can also add this number to your combustion chamber size, as well as compressed head gasket* volume and deck height, divided into total cylinder volume, to come up with a compression ratio.
For example, suppose you have a 350 engine, about 43.73 cubic inches displacement in a cylinder. In metric terms, which is the general measurement in an engine, this comes out to ~717 cc. To determine total cylinder volume, you add the displacement to the volume of the combined unit of the chamber/gasket/piston.
Now, using MY engine as an example, you have 62cc chamber heads, .005 deck height, .041 compressed height* of Fel-Pro 1003 head gasket, and a 22cc dish (reverse dome on piston). Your .005 deck height equals a little more than 1cc, we'll keep it there for simplicity. The head gasket itself has a volume of about 8cc (again, for simplicity sake). Add all of this up and you get 62+22+1+8 = 93cc.
Now, add the 93cc to the 717cc for total cylinder volume, in this case, 810cc. Divide 810 by 93 to determine compression ratio. This engine runs at about 8.7:1 compression doing the math above, which is about right.
* Compressed gasket height is the thickness of the gasket after the heads have been torqued to spec. The gasket is thicker and displaces more out of the box, until it's installed.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 11-17-2006, 09:31 PM
Ill have to try that out.
But can magnets stick to hyperuerutic pistons? its either a cast alum one or hyper.
Old 11-17-2006, 09:41 PM
wow ill get 8.34:1 compression, thats not good.
Old 11-17-2006, 10:58 PM
silicon212's Avatar
Confoundingly Lucid
A hypereutectic piston is a cast aluminum piston produced from an alloy with a high silicon content. The silicon adds strength to the aluminum, making the hyper piston stronger than a standard cast piston. Being an aluminum alloy, it is non-magnetic.
Are you sure of your numbers? Remember that a 1003 Fel-Pro head gasket is for a 350 and has a larger opening, and about 2cc over the 305 version. A shim steel gasket will have the lowest amount of volume, so you can use one of these to obtain a higher ratio. Keep in mind that with steel shim gaskets, you will need to retorque the head bolts about 500 miles or so from first startup.
Old 11-17-2006, 11:01 PM
Blue Bowtie's Avatar
Registered Offender
Or, if you're lazy (and have MS Excel) you can plug the numbers into this:
Engine Calculator
Old 11-18-2006, 11:58 AM
Engine Calculator
thats a cool thing BB. I did it with a 5cc flat top valve relief and .020 headgasket and came out with 8.8:1 but with a .040 gasket i get much lower, it makes a big dif.
I guess I know now that I can get almost 9:1 with these like I was planning.
Is there wway to get a compression ratio while the engine is together?
Old 03-15-2010, 05:41 AM
flemmingSundra's Avatar
flemmingSundra flemmingSundra is offline
Thank you for this wonderful forum
Say hi from Cyprus I have much tolearn from this great community it is a long time since I started to lurk on this community the first time, each time it is a amazing time.
cheers
I really hope to be able to do the community good.
