Go Back   Automotive Forums Car Chat > Honda > Integra
Old 03-05-2002, 09:19 PM
superfuji57 superfuji57 is offline
Send a message via AIM to superfuji57
Help on installing a short shifter...
I have a 95 gsr and the other day i tried putting in my short shifter...i took off the center console and found myself stuck where the shift lever goes beneath the floor....so can anyone list the steps to go further?? thanks....also does anyone know if you can use 2dr fenders on a 4 door integra???
Old 03-05-2002, 09:36 PM
kidrocket kidrocket is offline
Send a message via AIM to kidrocket
you have to go at it from underneath bud.
you dont need to remove the center console
your exhaust will get in the way and youll probably have some banged up knuckles when your done, but you need to disconnect the linkage from the stock shifter, and then there will be two more bolts keeping the shifter mounted in your car, remove those, and it should slide down. remove the boot from around the stock shifter, put it on the new one and reattch the parts you disconnected in reverse order.
Mine took a while cause i had never done it before, and its kinda scary just taking stuff apart but its worth it. good luck and come back if you need more help
by the way, my car is a 99 civic si, but it should be the same procedure
Old 03-07-2002, 11:02 PM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
Actually you do need to work up top too. There are two gold flat screw type things that hold on those bolts. One faces towards the front of the car and one towards the back. You will have to pull up a rubber boot that goes around a circle metal piece around the shifter. This is where you will find the gold flat screws. You will need like locking pliers type things to hold these annoying things while someone from underneath loosens up the bolts. THEN go from underneath and disconnect the shift linkage from the shifter and pull it around the exhaust. When you connect it back up do the reverse of removal.
Oh and make sure that if you have a heat shield that you take it off because your short shifter might bang up against it allowing you not to shift. If you need more help i am always here or if you need a little bit better explanation, you can email me @ [email protected]
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 03-08-2002, 12:03 AM
thanx
how to install short shifter? Civic_D16Y5 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 06-26-2004 03:57 AM
Installed short shifter...problems! T!mmy Engineering/ Technical 32 01-02-2004 06:13 PM
install short shifter 4g4d_getone '88 - '91 Civic | CRX | Wagon | Shuttlee 2 08-12-2003 12:58 PM
installing short shifters esko1269 '88 - '91 Civic | CRX | Wagon | Shuttlee 9 11-21-2002 06:36 PM
