Old 03-03-2002, 05:59 PM
MaFi0s0 MaFi0s0 is offline
having 2 dif size subs in the one system
i listen to high bpm and low bpm music, i have heard 8inch 10 inch and 12 inch subs but not 15, i find the 12s to be too big for high bpm music and the 10s are too punchy for slow jam etc. is it ok to fit say.. 2 10"s and 1 15" or 1 10" and 1 12".
no one does this but i cant see what would be so bad about it, if there both running at the same time, with an equalizer.
Old 03-06-2002, 09:04 AM
wellsit wellsit is offline
Send a message via ICQ to wellsit Send a message via AIM to wellsit Send a message via Yahoo to wellsit
Yes it can be done. If you have 2 amps, you could tune each amp to work best with each sub. (lower response for 12, 15's, higher response for 8, 10's). I wouldn't put them in the same box though.
Old 03-07-2002, 09:54 AM
KatWoman KatWoman is offline
Since 10's are too punchy for you..why not just do 2 12s and then get better midrange speakers?
Old 03-24-2002, 08:06 PM
cause that still doesnt match 10s
for example, my cousin has 2 7x10 kenwood mandrills 200 watts each
and a 1000watt 12
the 7x10 should give off some punchy bass but with the 12 you cant hear it,
theres this song i play in my car and it gives off way bigger bass than in my cousins car, cause the bpm is high it sounds crap on his 12s and it sounds mad in my car and eveything shakes from the boot to the steering wheel.
btw the song is nelly - tho dem wrappas
basicly i want vibration and spl
Old 03-25-2002, 08:30 AM
lloyd_nickens's Avatar
lloyd_nickens lloyd_nickens is offline
THe box for his 12 isn't built right. And Unless you run the 12 under 50 hz and the 10 from about 250- 50 hz the 12 will drownout the 10's
"God Bless BASS, What Would We Do Without It?"
"If You Can Breathe, Turn The Music Up."
Old 03-26-2002, 01:21 AM
LjasonL's Avatar
LjasonL LjasonL is offline
Some Guy
Send a message via AIM to LjasonL
i had 2 10's and 1 12 in my civic. sounded fine, no sounded awesome but not worth the complexity. try looking at a 12 from a really reputable manufacturer known for sq, it should give u all the punch and low range u need. look at jl and eclipse for starters.
Old 05-07-2002, 07:55 AM
put them in a separate airspace. the 12s will over power the 10s if you leave them in the trunk. try to do trick install and put the tens in your doors of florr (it can and has benn done). or you could just go with 4 jl12w7 and forget the 10's, of course you would be giving up the ability to hear afterwards but hey anything for a loud car right??!!
Whats the right size sub box? Mireault727 Car Audio 4 10-16-2008 10:47 PM
What is the difference between the SIZE of the subs? creative33 Car Audio 26 05-12-2005 05:15 PM
two 12" subs or one 15" sub 85GSi Car Audio 14 12-30-2004 12:39 PM
Zc transplant i have and the ones i dont have Touge180 '88 - '91 Civic | CRX | Wagon | Shuttlee 3 02-03-2004 11:38 AM
What size sub can fit comfortably in a civic boot? blitz_syd Car Audio 4 07-19-2003 11:48 AM
