Old 02-02-2004, 02:13 PM
Touge180 Touge180 is offline
Zc transplant i have and the ones i dont have
I have these parts so far
Thermostat
Water Pump
Oil pan gasket
Radiator Hose
RR main seal
Rear crank seal
Cam Seals
Dist cap
Dist rotor
Ex mani gasket
intake gasket
timing belt
And this is what i need to get tell me if i left someting out
Alternator belt
A/C Belt
Thermostat gasket
Front Crank Seal
Valve cover gasket
Head Gasket
Spark plug seals
Spark plug wires
Spark plugs
crx si throttle cable
Clutch kit
Si or zc tranny
Did i leave somthing out.......
My car doesn't look fast and my car doesn't look furious...so when you see my taillights fade into the distance, remember this: I was into cars long before you and the rest of the trend-humping lemmings showed up and I'll be into cars long after you move on to the next pop-culture trend that you decide to shamelessly bastardize
Old 02-02-2004, 07:05 PM
you guys aren'y goin soft are you
Old 02-03-2004, 01:13 AM
nemo_wolf's Avatar
nemo_wolf nemo_wolf is offline
Send a message via AIM to nemo_wolf Send a message via MSN to nemo_wolf Send a message via Yahoo to nemo_wolf
looks complete
AF Bay Area Crew
91 civic LX sedan : Dec. 3rd 01 - Dec. 9th 02
88 civic DX hatch : Jan 14th 03 - Oct 05
96 Zamboni Model 552 : done working there
00 Civic EX coupe : Oct 05 - Sept 2010
11 Scion xB : Sept 2010 - Present
Old 02-03-2004, 12:38 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
Re: Zc transplant i have and the ones i dont have
might as well get all your fluids and get some radiator flush and clean it out if your doing all that work, make sure everything works good
2002 Acura TL Type S
1991 Honda Crx Si
