Brake Light On Instrument Panel...
Ok, the brake light is constantly staying on no matter what. Actually in Park Or Neutral it's off(yes i have an auto) but in every other gear it stays on all the time! How do i disconnect it or fix or find out why it's on all the time? What would cause it to stay on?
1985 1.5 12Valve Carbed CRX Close_Call
"Modus Operandi" |
i had the same problem, it turned out i needed new pads on my brakes, the sensor was tripped cuz the pad was too low, that is my guess.
get new brakes.
Name: Scott Stable Of Cars I have Owned: 1991 Honda CRX 1990 Oldsmobile Cutlass Supreme 2003 Honda Accord 1998 Chrysler Concorde 2007 Honda Civic 1997 Toyota Camry 1995 Saturn SC2 1996 Ford Taurus 1991 GMC Sierra 2002 Daewoo Leganza 1999 Dodge Ram 2007 Honda CR-V 2003 BMW 325i |
Handbrake light? Pull your center console up and have a look at the brake lever. At the back, there's a wire that activates the light. Check that the actuator switch on it isn't broken or rusted and that it moves freely. Check the contacts on it to make sure they are clean (I'm doing this from memory with a 3G - should be similar with a 4G).
you may also wanna check your fluid level as it will also put the light on...
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh |
