Old 11-05-2004, 03:04 PM
lckycharm713's Avatar
lckycharm713 lckycharm713 is offline
body filler (bondo)
i been doing the body work on everything. kinda falling behind b/c of the weather up here in NY. i was wondering if the cold will have an effect on the body filler. its been around 40-55F degrees. seems like today it took longer to dry and harden up. lets just say it take twice as long to dry and set up, will it still hold? or should that be done on warmer day such as 55 and up?(like paint)
2000 Mustang - just a V6 with lots of good looks
1974 Camaro - 350 4bolt main .30 over, turbo 350 trans w/ shift kit.
1999 F-150 Lariat 4x4 5.4L
"Only babies suck bottles (NOS)"
Old 11-05-2004, 03:45 PM
y2icon's Avatar
y2icon y2icon is offline
Send a message via AIM to y2icon Send a message via Yahoo to y2icon
Re: body filler (bondo)
i dont know shit about bondo but it sounds like if it sees extreme heat upper 90's(dont think u need to worry about that in ny) it might have a problem. thats my opinion and contains no fact
Old 11-05-2004, 04:45 PM
4onFloor's Avatar
4onFloor 4onFloor is offline
70-80* is usually the prime temperature for spreading bondo, but you can still use it in 40-50* weather. it will take longer to set-up, but it will still hold just fine. i wouldn't use it when the weather drops below 40* though
Old 11-05-2004, 10:50 PM
ok then, thanks. the weather was like high 30s yesterday, but i didnt do anything b/c it was raining. i should have a couple mnore weeks of OK weather.
Old 11-06-2004, 12:04 AM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
as far as i know bondo can be used when its cold but not extremely cold
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 11-06-2004, 01:06 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
I wouldn't use it much under 50F also it's the surface temp of the car that is more important than the ambient temperature. Remember all the money you investet in pany plus all the time you invested will can be ruined if 3 weeks after you paint it that Bondo work you did it cold weather cracks or lifts etcc..,
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 11-06-2004, 01:31 PM
4onFloor's Avatar
also make sure you remove all oils from the metal from your fingerprints before you spread bondo. otherwise the first hot and humid day will cause it to peal
