i need more HP... i know the basics...
minor HP: intake & exhaust headers major HP: supercharger turbocharger NOS what else is there besides bore & polish the engine or an engine swap? i know this sounds like an ignorant question, that's because i am just starting to learn engines... please help.
PH member since June 2000 GroupOne in KC Co-Prez Head of Show Team GroupOne in KC |
disconnect your air conditioner they wont gain hp but it wll give you more usable power get an aftermarket air filter pretty much everything aftermarket serves some purpose so get an import cataolg and find what you need
new cams and cam gears
intake manifold |
There are only two ways to get more power out of your engine to the road.
1) Burn more fuel/air in a given amount of time 2) Transfer the energy to the wheels more efficiently Under 1, you're looking either at adding displacment, improving induction, or upping the redline - that's all. Engine Swap Changing displacment through bore and/or stroke mods Intake Cam adjustment/replacement Replacment head SOHC VTEC crossover adjustment CAI, intake port matching, etc. Forced Induction (Turbo, Supercharger, N2O, alchohol fuel, nitromethane fuel, etc.) Valve springs, removing rev limiter, other high rev adjustments (usually requires new head and other internals to truly take advantage of much up here.) 2) OK, well, there's a great deal to play with here Disconnecting accessories Exhaust cam adjustment/replacment Exhaust system mods Replacment head/exhaust port matching, etc. Fancy oil (e.g. RedLine Manual Transmission Lube) Auto-Manual tranny swap Smaller, less springy tires (yes, that gives you more power on the ground) Ignition systems Ignition timing There are also modifications you can make to use the same amount of power to make the car go faster: Weight Handling LSD Bigger, stickier tires Shorter gearing (often though the use of smaller diameter tires for track applications) Have I missed anything?
2000 Civic EX Sedan Plum w/ tan racing stripes for speed Si Rims Bridgestone Potenza S-03 (195/50R15) Rear Swaybar: Suspension Techniques 19mm Strut Tower Bar: Neuspeed Shocks: KYB AGX Springs: Ground Control Coilovers (Not yet mounted) 72 STS Photo by Carey Kriger |
LSD? i think you're right, on LSD i probably would think my car was flyin! seriously, whats LSD?
its also a fuel additive that gives temporary speed "highs"
LSD = Limited Slip Differnetial - jaxle is right
The differential gear is the gear assembly that allows one drive wheel to rotate at a different speed from the other. Before the differential was invented, cars used to only power one wheel. A limited slip differential prevents one wheel spin. This is particularly insidious on front wheel drive cars where the inside wheel will spin badly when turning sharply. When this happens, almost no power is transmitted to the ground. An LSD has a clutch-type mechanism between the two different half-shafts that prevents excessive slip while still allowing the wheels to go around a curve at different speeds.
