Old 02-18-2002, 01:57 PM
white97ex's Avatar
white97ex white97ex is offline
Send a message via AIM to white97ex Send a message via Yahoo to white97ex
clutch problems
i picked my car up with 84,000 on the odometer. and i beleive whoever had it before me put a high performance clutch in it. i used to have to put the pedal all the way to the floor for the clutch to engage fully, and it was stiffer than a stock clutch. now, there is some play in the pedal, from no pedal to the point where you find pedal it travels atleast an inch. and now it engages at about half pedal then goes to the floor. is this the clutch the slave cylinder...or just need adjusting??? if you need clarification i'll do my best
Old 02-18-2002, 04:30 PM
94_AcCoRd_EX 94_AcCoRd_EX is offline
Send a message via AIM to 94_AcCoRd_EX
It sounds like you're in need of new master/slave cylinders. When mine went out, at first there was just a little more play in the pedal, and then it got really bad, to where I pushed the clutch to the floor to engage it, and it caught about an inch off the floor.
1994 Accord EX coupe
Got Honda? Want Style? HondaStyle
Old 02-18-2002, 05:58 PM
pvang31019 pvang31019 is offline
try flushing the hydraulic system first
Old 02-18-2002, 06:38 PM
CivicEx95's Avatar
CivicEx95 CivicEx95 is offline
Banned
Send a message via ICQ to CivicEx95 Send a message via AIM to CivicEx95
Well, is it having trouble grabbing? If not, it probably just needs adjusting. I adjusted mine so it engages about an inch off the ground. I like to only have to lift my foot a little to have it engage. It was about halfway before, but with a heavy duty pressure plate, it was hard to get smooth engages when your foot is off the floor. If you need to instuctions on how to adjust it, ill post them out of my Helms manual.
Old 02-18-2002, 09:53 PM
white97ex's Avatar
me and my girlfriend worked for a foreign car repair shop. im gonna go talk to him tomorrow and see what he says.....how much am i looking at for a master/slave cylinder? ....parts only...thanx for all the help....... oh yeah i am grinding gears more often now..im sure its just because im not used to how the clutch has started engaging
clutch problem..i think bov3220 Engine, Transmission and Drivetrain 4 05-22-2009 12:17 PM
95-96 clutch problems/tranmission problem nickoolsayz Accent | Verna 0 06-23-2008 06:48 PM
tranny problems or clutch problems? crabby760 Let's get Technical! 5 08-28-2005 08:13 PM
CLUTCH problem, Exhaust problem alesserfate 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 16 10-06-2004 07:46 PM
Transmission/Clutch Problem? N321Q 3 Series 2 09-22-2001 03:39 PM
