Old 02-15-2002, 01:22 AM
SFF900 SFF900 is offline
cross-drilled/slotted or just slotted
I am getting better brakes when I swap a b18c in my civic, should i get drilled and slotted rotors or just slotted? I heard that drilling them weakens them? What am i best off with? thanks in advance
Old 02-15-2002, 03:20 AM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
slotted. all the benefits of cross drilling without the inherent weaknesses.
but then again, you'll never encounter cracked discs with cross drilled if you only drive your car on the street... unless you ride your brakes alot.
Old 02-15-2002, 02:38 PM
fritz_269's Avatar
fritz_269 fritz_269 is offline
Unless you're builing a car that will take hours on a real racetrack, solid rotors will give you the best performance. They conduct more heat away from the brake pads and fluid and are mechanically stronger so they're less likely to warp.
Modern brake pad technology has nearly eliminated green fade, which is the major reason for slots / cross drilling. Unless you are using race-only pads, you probably don't need it.
If you just want the look, stick with slotted. Cross drilled rotors are more likely to crack. If you really want cross-drilled, stick with the top of the line stuff like Brembo or Wilwood.
Cross Drilled or Slotted Rotors? 90CRXZCSi '71-'87 Civic | CRX 9 01-29-2002 10:02 PM
Crossed drilled/slotted rotors. kris Engineering/ Technical 14 01-26-2002 03:31 PM
Rotors- slotted or cross drilled?? slickkedar General 9 08-31-2001 10:44 PM
