Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 02-14-2002, 04:44 PM
Andy.uk Andy.uk is offline
Unhappy Bad Vibrations
My 95 Primera manual has suddenly gained a severe front wheel wobble.
After having gone 20 or so miles it starts vibrating intermittantly,seems ok on straight roads,but knocks round tight right hand bends and feels like left hand wheel will fall off.
It also shakes when power is reduced for slowing and slight r/h bends.
This happened after a bit of high speed aquaplaning....could it be related?
My local garage can find nothing wrong but say may need new left side C.V. joint - are they right?
Any advice would be much appreciated, thanks.
Old 02-24-2002, 02:04 PM
nismo_gt's Avatar
nismo_gt nismo_gt is offline
Put your steering on full right lock & then move foward slowly &
see if u can hear any clicking noises (try also to the left)
The CV joint is more likely to make a noise at its full travel
if u can hear it then replace it.
It could even be a front suspension drop link or leg, you really need
to get it back on a ramp & check thoroughly coz those
symptons ain't good
Find a way to recreate it easily & get back to the garage
Primera GT
Old 02-25-2002, 06:19 AM
eeyore eeyore is offline
Sounds like a suspension problem - best get it checked. If nothing is found, however, get your wheels re-balanced. If they are out of balance, then this will cause a bad vibration at certain speeds (not all speeds - it's dependent on how far out of balance they are).
95 JGCherokee bad vibration tjb6172 Grand Cherokee | Grand Cherokee SRT8 13 11-16-2004 07:44 PM
Bad Vibration sbrohman Cherokee 32 04-25-2004 06:30 PM
bad vibration hellkins Integra 1 02-02-2004 10:45 PM
bad vibration 4G63 engine zyman Galant 6 01-16-2004 10:44 AM
Bad Vibrations Civicalized Engineering/ Technical 3 12-03-2003 02:33 PM
