Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
View Poll Results: Worth getting?
Yes 1 25.00%
No 3 75.00%
Voters: 4. You may not vote on this poll
Old 02-10-2002, 02:40 PM
Morpheus XIII Morpheus XIII is offline
Relatively cost-effective SEQUENTIAL transmission
Ikeya Formula has designed a shifter add-on for S13/S14 Silvias, which converts your standard manual shiftgate into a forward/backward shift-setup. The unit is basically a non-electric, non-hydraulic, mechanically geared device which simply converts the shift knob's fore and aft movements into the regular |-|-| pattern underneath, where it is connected to the transmission. The clutch is still used for all shifting. I doubt it can shift much faster than a regular transmission equipped with a short-throw shifter, but at least it eliminates missed shifts. It would probably be most effective in road racing, but will likely be a pain in the rear for street cars, being that it doesn't seem capable of entering neutral from high gears without pushing the stick several times (it has a R-N-1-2-3-4-5 pattern). Also, engaging reverse requires disengaging a safety which looks a bit cumbersome. Something else to note is that the contraption extends upwards from the transmission tunnel, so looks a little hideous--also a sign that it's really made for the track. Interestingly, my biggest complaint is also its best selling point--the price. Close to a $1000 pricetag, it's a real bargain when compared to entire sequential transmissions. But at the same time, the small unit comprised of simple moving parts and a small gear meter doesn't seem worth all that money. I guess what you really are paying for is R&D. They've made it for some Skylines as well, and a few more applications are on the way. I suppose it would work for 240SXs outfitted with SR20DETs.
Click the link at the top for detailed information, thankfully, in English.
Old 02-11-2002, 02:32 PM
J SPEC SilEighty's Avatar
J SPEC SilEighty J SPEC SilEighty is offline
Send a message via AIM to J SPEC SilEighty
I think it's pretty cool, but it would become a pain on the street. also like you said, I don't know how you would enter neutral from higher gears quickly unless it has some mechanism or something on it that lets you quickly drop it back down to neutral
Overall I think it's pretty nice but I'd rather stay with my conventional shifter
Old 02-26-2002, 05:43 PM
NSX-R-SSJ20K's Avatar
NSX-R-SSJ20K NSX-R-SSJ20K is offline
Send a message via AIM to NSX-R-SSJ20K
cheap and chearful i don't think that thing would last a real sequential shift would be better naturally but as a substitue it cant be that bad!
I prefer normal gearbox anyways - just get a short shift kit
Qualified Automotive Engineer
Old 02-26-2002, 07:46 PM
PRECISELY how I feel.
Cost effective upgrades pete20 Almera | Sunny | Pulsar | Bluebird | Tiida | Versa | NX | Avenir | Tino | Stanza 1 05-23-2006 04:45 AM
Most cost effective? Aibo Car Buying Q&A 2 09-30-2004 12:27 AM
Cost Effective Mustang Turbo Setup HighRev87 Forced Induction 10 09-10-2004 10:21 AM
Cost effective upgrade pete20 Altima 9 07-11-2004 10:54 PM
Best cost-effective carbon fibre / kevlar decal? DSM-Mark Car Modeling 7 07-30-2003 02:00 AM
