Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 02-08-2002, 06:30 PM
bradboy bradboy is offline
Pistons H22 vs. H23
I just pulled the head of my turbocharged jdm h22a (10.6:1 Comp.) engine. I have the option of installing some h23a pistons (9.8:1 comp.) which are a direct replacement but lower compression. Is the strength the same between both or are the vtec pistons stronger.
93 Prelude Vtec-Turbo
Old 02-09-2002, 01:52 AM
pvang31019 pvang31019 is offline
cast is cast...but you better get it honed out...you just can't take off the head, oil pan and pull the piston/rod assembly in and out
Old 02-09-2002, 08:23 AM
Is is absolutely necessary to hone the block. If not what will be the problem?
Old 02-09-2002, 10:13 AM
texan's Avatar
texan texan is offline
Writer Mod
Cylinder sealing will be the problem. You can try to flex hone the bore, but if there are any real problems with scoring or serious imperfections (or possibly even out-of-round cylinders) this method will not fix them. Go here for product info.
'03 Corvette Z06
'99 Prelude SH
h23 swap 4th gen civic? 92lude91dx '88 - '91 Civic | CRX | Wagon | Shuttlee 4 03-16-2009 11:43 AM
H22 to H23 Manual Tensioner A Must 4 any H22!! Willb2305 Classifieds 1 07-06-2006 04:10 PM
Which model Preludes come with the h22 or h23? Hybrid1990crx Prelude 12 01-01-2004 07:47 AM
H22 vs. H23 crj_lll Prelude 1 04-10-2003 06:38 PM
h22 or h23 dominate9 Forced Induction 2 05-21-2002 12:58 AM
