Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Audio/Security
Audio/Security car audio, security.
Old 02-08-2002, 12:01 PM
ky_infiniti2000's Avatar
ky_infiniti2000 ky_infiniti2000 is offline
Send a message via ICQ to ky_infiniti2000 Send a message via AIM to ky_infiniti2000
Sub amp stoped working
Last night, my sub amp stopped working.
I worked fine for over year, and last night it wuit working.
I was not pushing it hard at all.
The power LED on the amp, stay a constant RED(protected) instead of GREEN(power). Any ideas where I should start troubleshooting this problem?
courtneyb
Old 02-08-2002, 12:25 PM
A380Driver A380Driver is offline
Send a message via AIM to A380Driver
Check the fuse?
Uhmm you may have blown something internally inside...soo that could have been a problem.
-Brian Jones
I got a snake man
Old 02-08-2002, 12:34 PM
Originally posted by A380Driver
Check the fuse?
Both the external fuses on the amp are OK and the InLine fuse is OK.
Old 02-08-2002, 12:46 PM
You can try removing all power sources to it that may reset it. If its in protected mode, there may be something in the amp that needs to be reset. What amp was it again?
-Brian Jones
I got a snake man
Old 02-08-2002, 01:04 PM
The amp is an Orion Coblat series. I forget the model. I will check here ina few, i need to run out from work for a while..
Old 02-08-2002, 05:01 PM
FOUND THE PROBLEM
Well, I rewired the subs in series and found only one sub working, so i pulled the non-working one out. I discovered the wires from the termials to coils were touching. i seperated them, and re attached the sub, and bingo, all systems are a go...
Stock Radio for installing Subs/Amp? robkule422 Car Audio 8 02-01-2011 07:29 PM
Confused! Which amp will work well with this sub?? Fed Car Audio 1 07-19-2008 10:27 AM
Box for sub? Amp work w/ sub? Newbie Q's again kyman_33 Car Audio 6 04-02-2005 03:01 PM
Car stoped working. Urban_Squrill Off-Topic 7 04-19-2004 05:30 PM
Sub/amp issue.. they stopped working 90gs Car Audio 2 08-04-2003 04:55 PM
