Old 04-01-2005, 06:25 PM
kyman_33 kyman_33 is offline
Box for sub? Amp work w/ sub? Newbie Q's again
Ok, so in that other thread you guys were barking at me to not get MTX subs.
So would this setup work:
Atlas 15
w/ this phoenix gold amp:
http://www.cardomain.com/item/PHOR501
and w/ this head unit:
http://www.cardomain.com/item/PIODEHP6700MP
Then if that does work where is a link to online where I can buy a box that would fit the Atlas 15?
Would this work?
http://www.cardomain.com/item/QLCQLH15015SE
Please, do not tell me you will bulid me one either. Nothing against any of you, but if I am buying one its gotta be in "real life" at a store or from a company online.
Old 04-01-2005, 11:56 PM
Diceman83's Avatar
Diceman83 Diceman83 is offline
Send a message via AIM to Diceman83
Re: Box for sub? Amp work w/ sub? Newbie Q's again
I don't really have the experience to advise you on the amps or head unit (just look at what I have ), but I think that box is gonna be way too small. My box is in the middle of the range of volumes for my sub, and I think most people would agree that going at or below the minimum volume recommended for the sub significantly reduces it's output and efficiency. I don't know the specs for the Atlas 15, but I'd think it'd be a bit bigger than 1.5 cu.ft.
Old 04-02-2005, 09:33 AM
balls_to_the_wall's Avatar
balls_to_the_wall balls_to_the_wall is offline
Ok, heres my $.02....80 bucks for a box, I built mine for 27.60 And that included the plans from NG. I don't know if 5/8" MDF is gonna cut it with a atlas 15, im not very familiar with the sub, but I am not sure if that box is thick enough, I would make it out of 3/4" MDF
As with Dice, I don't have enough knowledge to advise with the head unit or amp either....
Later
-Ryan
Old 04-02-2005, 02:23 PM
I'd build a box, but I have no acess to any type of building tools. H*ll, I don't even really know how to work much but a screwdriver and hammer. I don't really want to buy that box at all, thats why I was asking for suggestions on here.
Thanks for the advice,
Kyle
Old 04-02-2005, 02:43 PM
you might try going to a local audio shop and seeing how much it would take to have them make you a box...
Old 04-02-2005, 02:46 PM
Diceman83's Avatar
Well, if you insist on buying something... ebay has some stuff:15" box. It's only like $44 to $48 with shipping.
Old 04-02-2005, 03:01 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
Where are you located? If your anywhere close to here I can help you build a box. The head unit is fine you'll be happy with it. The sub is great. As far as the amp goes I would get this http://www.cardomain.com/item/PHOX4001?ref=deal over the other one so that you can full power it and have a little headroom instead of under power it.
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
