Old 02-05-2002, 08:54 AM
honda720 honda720 is offline
Send a message via AIM to honda720
Rebuilding engine
when an engine is rebuilt what are the parts that are replaced?
Old 02-05-2002, 01:18 PM
fritz_269's Avatar
fritz_269 fritz_269 is offline
Depends on just how much of a rebuild... Potentially everything except the block; down to just the top two piston rings and any bearings that look scuffed.
But the basic rebuild usually runs more along the lines of:
piston rings
crank & rod bearings
most gaskets and seals
And usually some machine work to 'freshen up' the cylinder bores and the deck.
If the heads are rebuilt too, it often takes:
springs & retainers
valve guides (only the worn ones)
valves (only the worn ones)
valve stem seals
Old 02-05-2002, 01:29 PM
soul180's Avatar
soul180 soul180 is offline
hey fritz, where is a good plcae to find all the bearings and seals and what not you are tlaking aobut? just lordco or or soemthing?
UGSTYLES
2000 z71, 5.3 budget rebuild, any tips nthnkng33 General Discussion 2 07-20-2010 09:06 PM
1994 f150 5.0 rebuild spoovey F Series 4 03-19-2010 06:30 PM
Engine Honing schri00 Engineering/ Technical 6 01-30-2010 10:43 PM
Engine Rebuild abc234 Aveo 1 05-17-2009 06:38 PM
rebuild engin! ice_rr '88 - '91 Civic | CRX | Wagon | Shuttlee 11 02-17-2003 06:51 AM
