Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Suspension
Suspension setups, shocks, springs, tires, handling.
Old 02-05-2002, 02:44 AM
pche059 pche059 is offline
Send a message via ICQ to pche059
Tein type NA vs Eibach/Koni for p11?
ok....
first of all which suspension combination gives better handling?
does anyone here know the spring rates of the Eibach prokit for p11?
are the koni shocks stiffer or tein's?
tein owners...
what is the ride like on the lowest possible settings?
does it bottom out at all?
and how low does it go? would you say it's WOW LOW?
can i use my 42mm eibach springs with the tein shocks?
thanks guys
Patrick
99 Primera P11
One stripped down Primera
Old 02-05-2002, 07:46 AM
G-Forces's Avatar
G-Forces G-Forces is offline
Banned
The TEIN's are too softly sprung and you can bottom out easily when you start to push it a bit. Not a good track setup but IMO better than Eibach/Koni's.
On the lowest setting it looks nice low now stupid low. You should cut your bumpstops to get some more suspension travel if you get the TEINS.
Old 02-05-2002, 12:08 PM
kenchan's Avatar
kenchan kenchan is offline
im gonna raise it up 2 perches when it gets warmer outside.
gforces- do you know how to get those c rings off? just take a screw driver on the closed part of the C or is there a special tool for that? thanx.
1998 Prelude SS - TEIN HA with upper pillows, SSR Integrals 17x7 with SP8000 (215/45), GReddy Evo catback, Iceman Comp Intake, DC Sports header, Apexi VAFC, ZEX 55 shot with bottle heater, NOS blanket, Factory Body Kit, Spoon F/R tower bars, JDM Foglamps, Carbon Fiber trim, Razo pedals &knobs, Fiamm Dual air horn
Future Mods: Lighten car, 2nd 10lbs nitrous bottle would be nice too.
2001 G20 P11 AT- TEIN NA, TRM Snipers 17x7 with Potenza RE910 (215/45), Arospeed Dual-outlet Muffler, K&N Drop-in Airfilter, WW Front Lip, Nakamichi MB75 1DIN 6CD Changer/Receiver, FIAMM Dual Air horns, Levoc Pedals, PIAA (H4 Superwhite H3 Ion Crystal, 168 SuperWhite)
2002 WRX MT- TEIN HA's with upper pillow mounts, 1000Miglia HT3 17x7 with sumitomo HTR+ 225/45/17, painted side skirts, Cusco front & rear strut bar, Whiteline rear swaybar, aluminum endlinks, Blitz NUR Catback, HKS seq. BOV, factory front lip, rear valance, Kartboy short shifter and bushings.
Future mods: dressup wheels with Potenza S03 225/45/17 tires, TurboXS UTec, maybe an uppipe. by then, it'll be fast enough.
fiamm dual air horns.
Old 02-05-2002, 01:48 PM
Jas: do you know if the eibach springs are harder or the tein ones ar?
and would you say the tein shocks are stiff/good?
what life span do you think they have?
Patrick
99 Primera P11
Old 02-05-2002, 03:32 PM
Mrcoilover Mrcoilover is offline
The tein's have a nice ride. I have mine on the 2nd lowest (out of 3) setting. I feel they could go on the lowest. I have the damper settings on firm but not too firm (11 clicks from firmest). This is the only setting I have used thus far. I think it handles pretty good. I've ridden on progress/kyb non adj before on another car and I'd say the teins handle better. My car looks low, but I want lower. There's a big visual difference between the eibachs/teins. Our highest setting is still lower than the eibachs. I'm satisfied with mine. It handles pretty good even without aftermarket rims. They are expensive though but I don't regret getting them.
*Mod List*
2 JL audio W3 12's
Rocksford Fosgate 600w amp
Tein type NA (1.7)
Nokya Arctic purple headlight bulbs
Rims coming soon...
"I always ride dropped, how bout you?":finger4:
Old 02-05-2002, 03:34 PM
G22DET's Avatar
G22DET G22DET is offline
Send a message via ICQ to G22DET Send a message via AIM to G22DET
i would also recommend the TEINs over eibach/koni..mainly because, unless you are of a rare breed whom autox or road race your P11, you want to lower the car to look nice, increase a bit of suspension performance without sacrificing ride comfort. In the TEINs, not only can you adjust the levels you want to lower your car, (so it'll look nice) you also have 16way dampening adjustability (so it'll be comfortable when you want it to be and you can increase the suspension performance when you adjust to stiffer settings). It's the ultimate street set up in my opinion and i think many TEIN users will back me up on this one.
Luke C.
GDA Power!
Old 02-05-2002, 03:53 PM
ok...
well do you guys know how long would these shocks last?
has anyone here worn them out already?
or are they one of those that will "last forever"...?
or have they only got a life of 50000 km ..like the oem ones?
Patrick
99 Primera P11
Old 02-05-2002, 04:01 PM
G-Forces's Avatar
Banned
No shock will last forever. They should last a long time after all. Once they start getting a little mushy just jack up the hardness. You should be able to get at least 50k out of them.
Old 02-05-2002, 04:33 PM
hey do you guys know if the shock absorber itself actually has a shorter body than standard oem ones?
i mean to go 50mm lowered the shock body better be shortened...
another thing is...
are the springs from the NA kit same diameter as the eibach ones?
coz i wanna use my eibach springs with the NA struts ...dunno if i is gonna work tho...can anyone clarify this for me?
Patrick
99 Primera P11
Old 02-06-2002, 05:42 PM
G20 SpoRt 2002's Avatar
G20 SpoRt 2002 G20 SpoRt 2002 is offline
Banned
Send a message via AIM to G20 SpoRt 2002
I have the eibachs and I love the way it looks and drives!!
Old 02-06-2002, 11:54 PM
ok guys..another few questions for you
ok I am getting hooked up with a set of second hand Tein NA for my p11
i think it only comes with the Shocks and Springs...
nothing else
is there anything else that i will need to get it on my car?
or any tools that i will need to adjust my ride height...or the dampening rate?
and the availability of those tools in the aftermarket?
please help here
Patrick
99 Primera P11
Old 02-07-2002, 08:16 AM
nothing else
please help here
All you need is the click tool. You should make sure you get it from whoever. You can do it without it but just to be on the safe side, get it.
*Mod List*
2 JL audio W3 12's
Tein type NA (1.7)
Rims coming soon...
Old 02-07-2002, 12:14 PM
kenchan's Avatar
never really need that click tool. i just turn the knob with my fingers....
Old 02-07-2002, 04:02 PM
Thanks for the reply guys,
so does it mean that... if all i am getting are the springs and the shocks nothing else,
i can still get them installed correctly and they will still be fully functional, ie height and dampening rate adjustable?
Patrick
99 Primera P11
Old 02-07-2002, 04:04 PM
Yeah, you really don't need the tool but I just have it b/c it came with it. It won't bite you in da a$$ if you don't get it. springs and shocks is all ya need kid.
*Mod List*
2 JL audio W3 12's
Tein type NA (1.7)
Rims coming soon...
FS: P11 TEIN Type NA TourinG20 Classifieds 2 06-23-2002 06:18 PM
H&R vs Eibach springs for P11īs bafo Suspension 14 03-24-2002 09:16 PM
Want Eibach springs for P11 Kenny-G Classifieds 0 12-18-2001 01:37 AM
GC / Adjustable Koni set-up for P11 for sale.. zerogee321 Classifieds 5 07-22-2001 06:40 AM
TEIN type NA: HP11 for P11? kenchan Suspension 13 06-17-2001 09:30 AM
