Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 02-04-2002, 01:03 AM
94tegRS's Avatar
94tegRS 94tegRS is offline
NOS, what else do I need?
ok, I found this hit on JCWhitney for 499.95 and I was just wondering what else I need to buy to complete the kit if anything, and how hard is install on these? I am prettyu smart about cars, ive swapped bug engines, rebuilt one(and it DID run ) and ive done all the regular maintenance to all my cars. anyways, i just bought a 94 RS with I/H/E and am considering AEM tru power pullies, but i dont know if they really do anything, do they?
also I dont ant to spend the monrey on a SC (~4,000) but i do want a bit more performance, the NOS wont be used much at all, it is just in case im losing... like an insurance sorta. anyways, what else is needed?
Thanks
http://www.jcwhitney.com/item.jhtml?ITEMID=43614&BQ=sc
and I was remembering something about wet systems were better but im not sure, anyone know of a comprable price wet system.
and I am already thinking of getting http://www.jcwhitney.com/item.jhtml?ITEMID=43694&BQ=sc
and does anyone knoe where i can get a 12V DC botle heater for cheaper than 120bucks! and is it really necessary, i mean is it DANGEROUS without one, i will get one eventuall propably but i dint htink i can right now.
also, i know you should only spray at WOT, but with a stick, how do you do it when you shift, or are you supposed to keep youre foot on the gas while you shift, but then if you arent fast enough and the fuel cutoff hits, then you will blow up wont you?
do they have a switch that only lets the n20 flow when at WOT?
Thanks
Old 02-04-2002, 04:16 AM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
Do u mean what else do u need as in Internal motor work??
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 02-04-2002, 02:48 PM
94tegRS's Avatar
i mean is there anything i should buy as far as extras for the kit, a 50 shot will run fine with stock B18B1 internaals wont it. and as long as I just dont go crazy wiht it. also what is better wet or dry, i saw the other post and some said wet are safer but some said it would bew no problem with a dry kit if it was a small shot like 50, and how does the dry kit "trick" the ECU into giving more fuel, i read this but didnt understand how. it ws something about there was more pressure to the injectors so it delivered motre fuel also.
Old 02-04-2002, 04:23 PM
94civic's Avatar
94civic 94civic is offline
all i know is that the wet kit is for higher horse power like 100- whatever shot of nos and the dry kit is for low number like a 50 or 75 shot
Old 02-05-2002, 10:23 AM
94tegRS's Avatar
this may sound dumb, but how does it work, I know when it burns it releases more oxygen to burn more fuel or whatever but when you want to use it, do you press a button and it stays on for lie 10 seconds or can you choose how long?
Old 02-05-2002, 12:05 PM
94civic's Avatar
its for a s long as you hold the button, its not recomended to hold it for more than 15 seconds though
1994 civic ex - b16a sir2 w/lsd
too much to list
http://www.cardomain.com/memberpage/423478
Old 02-05-2002, 03:56 PM
94tegRS's Avatar
oh you have to hold it? I was toild be careful when you shift to not hit rev limiter because the engine will be too lean, but how am i supposed to keep the buton pushed while i shifted anyways, I am not gonna mount it on my shift knob, also, what abouyt using it like towards the mid-end of 3rd gear, let off about 200-300 before redline, and then shift to 4th, and then spray again. what about using it in like the beginning of 3rd aldso, or even end of second- through 3rd, becasue someone told me top only use it in 4th or 5th, but I cant get it into 5th anywhere around here. and even 4th is pushing it, thats pretty fast for the lil back road thats raced on. and how safe on your engine is a 50 shot. I know it is always safer without it, but does 50 shot dramatically reduce engine life? like say used like 3 times a month. and how expensive its it to filla bottle. is there anywa for like 650 bucks to get the same power or close to it, but that will be used always and is safre on the engine, and... LEGAL! I was thinking, for 650, I could propably get like higher compression pistons, and while im sat it replace bearings and rings, and mabe some cams or soemthing, but then it will get worse mileage right? well the higher compression would get better wouldnt it, same mixture but hotter explosion, anyways, with the nos it is stock economy until you use the nos.
whatb webpage could i look at to find internals for this car?
Old 02-06-2002, 09:39 AM
FLAWLESS FLAWLESS is offline
Send a message via AIM to FLAWLESS
This kit will spray using a Wide Open Throttle switch. This means when the system is armed, it will spray when you have it floored. When you take your foot off the gas, it will stop. This is the safest way.
You can spray whenever you want, 1,2,3,4,5 gear. Just floor it and go. It makes no difference cause it's coming on at WOT.
98 Civic LX - Bottle-Fed
Old 02-06-2002, 11:31 PM
94tegRS's Avatar
ok, well I thoiught in first, Ill just spin them all the way through the gear. I omnl;y have some cheap road hugers or somethingf and am going to get some ZIEX or some FZ4 or soemhting, i really want T1-S but trhey are lie 199 each
Old 02-11-2002, 07:08 PM
joe holeshue joe holeshue is offline
depending on where you live you'll need a permit to fill your bottle
Old 02-12-2002, 12:50 AM
94tegRS's Avatar
everett WA is wheere id fill it, maybe lynwood or seattle if i had to go that far
Old 02-12-2002, 11:05 PM
Self's Avatar
Self Self is offline
Send a message via AIM to Self
Looooong Answer...but helpful
I'm gettin in on this a little bit late, but I think I may still be able to help you out a little bit. The main difference between a wet and dry nitrous kit is this...A dry kit sprays THROUGH the Mass Air Flow(MAF) of the car(the "thing" right after the intake). By doing this, the MAF senses the extra amount of oxygen(b/c of the n2o), and forces the ECU to inject more fuel into the air/fuel mixture going into the engine. This system is simple yet effective, and usually cheaper than a wet kit. Also, it is best used for low hp applications(anything up to about 100) b/c it's not a precise as a wet kit.
Now, a wet kit sprays AFTER the MAF. Where the dry kit has only a single solenoid for the nitrous(solenoid = the "thing" that pumps the nitrous), a wet kit has TWO solenoids. One for the nitrous, and another for the fuel. What happens is a controlled amount of nitrous is pumped by the nitrous solenoid and mixed with a precise amount of fuel pumped by the fuel solenoid. This mixture is then injected into the engine. Here's a great pic of a wet setup on an LS1 engine(same idea basically for an import) http://musclecartechnologies.com/NXP...s/DSCN0115.jpg .
The third type of set-up is called Direct-Port Injection. It's like a wet system in that it has seperate fuel and nitrous solenoids, but instead of mixing the two and then spraying them into the engine, a line from both the fuel and nitrous pumps are plumbed directly into EACH SEPERATE cylinder. To SEE exactly what I'm talking about, go here... http://musclecartechnologies.com/NXP...s/DSCN0235.jpg GREAT pic of a direct-port setup on an LS1 engine(v8 Camaro).
Wet kits are moe expensive than dry kits, but they are relatively more "safe", and precise, especially for higher HP applications(100 - 200).
You will notice that you are burning more fuel during nitrous use. You will notice that your clutch will go away sooner rather than later(although with only a 50 shot, it won't be TOO quick).
If you want a system with all the "goodies", look to spend close to an additional $400. This would include a WOT(wide-open throttle) switch, a purge set-up, a bottle heater, a window switch, and a fuel-safety switch.
A bottle heater isn't "necessary" but what you will notice is that you will be spraying, and it will suddenly feel like the n2o is off, even though you're still spraying. This is b/c the temp(and therefore pressure) has dropped too far for the solenoids to pump the nitrous any longer. The heater prevents this. The WOT switch has been explained before. A window switch is used to only allow nitrous to be used during during two specified RPMs, or a "window". This will help prevent spinning, and spraying near your rev-limiter. A fuel-safety switch is EXTREMELY important, in my opinion. What it does is it keeps tabs on your fuel injectors. If they for some reason fail(stop injecting enough fuel for the n2o), then the switch activates and cuts off your nitrous. If you don't have one and your injectors fail, say good-bye to your engine, b/c injecting straight nitrous will cause a few..."problems"
Well anyways, that's about all I can think of now. I know it's a TON of info to suck in, but try. And if you have any more questions, ask away, I'm glad to help!
There's no replacement for displacement...No, not even a turbo.
Old 02-13-2002, 01:28 AM
redline201 redline201 is offline
Self
thanks for droppin some knowlege on my ass
Old 02-13-2002, 02:11 AM
94tegRS's Avatar
well, I can buy a high pressure pressure plate and a new disc and throw out bearing and do it myself putting in, I know for a bug the clutch is liek 50 bucks, but for an integra and a performance clutch it will be a bit more, say,... 300 or so? I have no lcue? anyways, would a hi. per. clutch last longer? and as far as the extras, i found the kit for 450, I ofund the purge valve for 100, the heater fr like 180, ythe remotoe opener for 180, it already comes with the WOT switch, and i gues i need to fnd a woindow switch and canany work or does it have to be a zex window switch, also a fuel safety switch, how much are these?
Old 02-13-2002, 10:52 AM
Self's Avatar
I don't really know what a good brand of clutch for imports is. Maybe ask around in the technical section, they can probably help you out with that over there. Either way, unless you REALLY know what you're doing, I wouldn't suggest installing your own clutch. It's a very delicate process, and if everyhing isn't lined up, spaced, and installed PERFECTLY, not only will your clutch end up a smoking hunk of useless metal, but you risk hurting your entire transmission. Anyways, a fuel safety switch will run you about $80 - $100 I'm guessing. I'm pretty sure you can find a heater for less than $180, $120 sounds more reasonable. Search around for lower prices on that one. Also, like I said, I don't really know too awfully much about import performance clutches, but for a domestic, a Star SPEC Stage III runs about 450. On my last vehicle, my clutch install was $350, so expect something like that. Any more questions? Glad to help
What else needed for 5 speed swap 99 accord? Willb2305 Accord/TSX/Accord Hybrid 0 06-28-2006 12:59 AM
what else needed? CRXkid '88 - '91 Civic | CRX | Wagon | Shuttlee 2 07-26-2002 09:14 AM
I'm building an LS/VTEC, what else do I need, please read. Maryland90Hatch Engineering/ Technical 3 03-12-2002 07:41 AM
what else do i need for turbo? 94tegRS Forced Induction 4 02-26-2002 01:33 PM
What else do I need??? Phat_Si Forced Induction 7 01-07-2002 10:23 PM
