Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Suspension
Suspension setups, shocks, springs, tires, handling.
Old 01-30-2002, 11:26 AM
ky_infiniti2000's Avatar
ky_infiniti2000 ky_infiniti2000 is offline
Send a message via ICQ to ky_infiniti2000 Send a message via AIM to ky_infiniti2000
Question about P10 shock install.
I can't remember where i read this, but how do u remove the rear shocks on the P10? Something about removing the rear seat and the rear deck?
courtneyb
Old 01-30-2002, 03:26 PM
bump909's Avatar
bump909 bump909 is offline
Registered User
yup, remove the rear seat and rear decks and you'll figure it out. it's not that bad.
Old 01-31-2002, 12:58 AM
JustinP10's Avatar
JustinP10 JustinP10 is offline
Send a message via ICQ to JustinP10 Send a message via AIM to JustinP10 Send a message via Yahoo to JustinP10
Yeah, there are two little pull tabs in teh front of the lower section, pull those as you lift up on the seat, then pull that part off. The next step is removing the back part of the rear seat. There are 4 screws (i think) one in each lower corner. and then there are two behind the cover where the armrest folds up into. Once those are removed you can lift up and remove the back part of the rear seat. Then in the upper left and right corner you will see the top mounting points of the rear struts. There are 3 nuts holding each side up. I think they are 14mm? (it's either 12 or 14, i think 14? it's been a little while since i've touched mine)
Once you get those undone, the two bolts on the bottom, and the brake line are all that's left to remove the whole assembly. The hardest part is undoing the top bolts while trying to hold the strut up from outside the car, at the same time... with two people it's simple, if you're by yourself, it just takes a little longer, but it's not that big of a deal. Hope this helps.
Justin McClanahan
95 G20
15.4 @ 91.4mph (2.4 60ft )
143.7whp and 131.4 ft.lbs
Primera (10:1) Intake Cam, HS CAI, HS Header, UR Pullies, 19* Timing, ACT, Lightened Stock Flywheel, GC/AGX, Pacesetter Short Shifter, and more stuff...
Old 01-31-2002, 06:42 AM
P10DET's Avatar
P10DET P10DET is offline
You don't have to remove the rear deck.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 01-31-2002, 07:40 AM
bump909's Avatar
Registered User
that's true.. come to think of it, i didn't take my rear deck off. i didn't even know how to at the time.
Old 01-31-2002, 10:14 PM
nis.k.a.'s Avatar
nis.k.a. nis.k.a. is offline
Pull tabs are in 93.5 and above. The older ones where simply pull up on seat. Only 2 screws holding in backing.
nightmaR3Z
Old 02-06-2002, 03:20 PM
jayntguru jayntguru is offline
I'm confused. In my 93.5, there are 2 screws at the outside and two bolts behind the center armrest.
-Jay
1993.5 G20
http://www.nx2k.com/G20/
11 second GSX
http://www.nx2k.com/eclipse/
Old 02-06-2002, 05:23 PM
nis.k.a.'s Avatar
I'm talking about the bottom part. The part you put your butt on.
nightmaR3Z
Old 02-18-2002, 02:12 PM
Blue94G20T Blue94G20T is offline
Nor did I have to remove the rear seats. I guess because folds down . Anyways here is a picture after the seats were down. You can notice how easy it is to get to now.
Ron
1994 Blue G20T
ShigSpeed Coilover, 17" Dronell TS05 wheels
Old 02-19-2002, 01:40 PM
nis.k.a.'s Avatar
You have a G20T. For those of us who don't have a solid backing which needs to be removed.
nightmaR3Z
question about stock shocks kingcarm 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 5 11-30-2004 04:15 PM
Questions about Viper alarm installed in car before I bought it Jfo Car Audio 7 05-23-2004 02:42 AM
quick question about P10.... lukeyc3 General 3 03-05-2002 03:33 AM
