Old 07-16-2004, 11:35 PM
S-WRX S-WRX is offline
Can you wetsand a painted shell with 2000 grit paper
Quick question to all the pros, I went to www.italianhorses.net and was looking at the painting tutorial. the website says to wetsand with 3200 grit sandpaper if you managed to get dust on the paint. The problem is, I was looking for a 3200 grit sandpaper at pep-boys today and the finest they have is 2000 grit sandpaper. Can I wet sand lightly with 2000 grit without scratching the paint?
I need help on this one, my ferrari is almost done!!
Thanks!
Old 07-16-2004, 11:37 PM
Jaymes's Avatar
Jaymes Jaymes is offline
Re: Can you wetsand a painted shell with 2000 grit paper
people here said that you can wetsand with 2000 grit to remove things and then use compound and wax afterwards.
Old 07-16-2004, 11:43 PM
JTRACING's Avatar
JTRACING JTRACING is offline
J.E.T.
you probaly can, but if you have a really nice paint job, id recommend sanding with really fine paper, like 15,000 grit, then go over it with meguires scratch-x , it will give you a mirror finish
Old 07-16-2004, 11:44 PM
Jaymes's Avatar
^^ Someone here said he uses 2000 Grit and then Meguiar's Scratch X... would this still work for a mirror-like shine?
Old 07-16-2004, 11:49 PM
351Cougar's Avatar
351Cougar 351Cougar is offline
I think 2000 would cut through the paint way too fast. I start with 3600 and go up to 12000 then use meguiars.
my name is Justin feel free to use it
69 Cougar 351W fmx 3.00s 17x8 06 bullits... sold
92 Camaro RS 305 tbi T-5 purple haze metallic (92 color only 1 of 8,556) - custom ram air, lowered
88 AE92 4afe powered sedan.. got it for $250
Old 07-16-2004, 11:51 PM
I forgot to add, the current paint on the shell is a base coat. I have about 3 light coats, in which by the third coat, the paint somehow collects dust. so should I paint over this right now and sand it later, or should I sand it first, then go for thick finish paint.
Old 07-17-2004, 12:32 AM
Jaymes's Avatar
Wow where do you find these sand papers?!
Old 07-17-2004, 01:13 AM
sjelic's Avatar
sjelic sjelic is offline
Then there is no problem at all if you have to add few more coats, just don't push to much and reach the primer. Just use 2000, dry it well and give few heavier coats, if you use clear coat then even if you wet sand final colour with 2000 you will get perfect paint.
Sasa Jelic
SCALEMAKERS
Old 07-17-2004, 01:19 AM
Mainomega Mainomega is offline
where do you find 15,000 grit sand paper ... or is that just silk ?
Got Something Good ? E-mail me
Old 07-17-2004, 01:55 AM
JTRACING's Avatar
J.E.T.
i find it at my local hobby shop
Old 07-17-2004, 02:28 AM
hobbes874's Avatar
hobbes874 hobbes874 is offline
Send a message via AIM to hobbes874
I recently used 1500grit on a GT2 and it turned out great, I used a combination of Tamiya's Compound and Meguiar's "Swirl Remover". Extreamly smooth and shinny finish
All Newbies please read the F.A.Q's
"We are defined by the choices we make." -Fight Club
Old 07-17-2004, 03:43 AM
GT-Alex's Avatar
GT-Alex GT-Alex is offline
Send a message via MSN to GT-Alex
Re: Re: Can you wetsand a painted shell with 2000 grit paper
Try a search for micromesh polishing kit, it come with 3200 to 15000 grit sandpaper and a foam block.
Old 07-17-2004, 03:57 AM
youngdrifter_x's Avatar
youngdrifter_x youngdrifter_x is offline
Send a message via AIM to youngdrifter_x Send a message via Yahoo to youngdrifter_x
where can i obtain this high number sand paper?
I use 2000 in running water...and imo my paint jobs come out good. all i need now is some compound stuff and i might get a good p-man shine :-D
-Andrew R.
Old 07-17-2004, 10:44 AM
minniebanister minniebanister is offline
Look here: http://www.hobbylinc.com/cgi-bin/s5....1.x=10&I1.y=18
S-WRX, if you are going to try removing dust specs with anything less than 3200 grit, be very, very, careful. If you screw up, you will cut through to the plastic. If you don't screw up, the result will be quite deep scratches. Hopefully your next coats will cover up these scratches but don't forget the maxim "paint hides nothing".
Old 07-17-2004, 10:51 AM
Vric's Avatar
Vric Vric is offline
Tamiya Coumpound is like a 9500 grit sand paper. I think over that it's totally useless.
If your paint job is ok, use coumpound then use a Carnauba wax like Meguiar's Deep Crystal System
