Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 01-30-2002, 12:25 AM
Phrak Phrak is offline
Send a message via AIM to Phrak
Iridium Spark Plugs
Denso (http://www.densoiridium.com) have some Iridium Spark plugs, and I've heard reports that these puppies will increase performance and throttle response somewhat... Can anyone help with some more info?
a) Is this true?
b) Does anyone know what plugs the H22a uses?
c) How MUCH better are they than, say, NGK Platinums?
All help is appreciated
Tim.
Old 01-30-2002, 02:14 AM
rybred rybred is offline
Send a message via ICQ to rybred
I read on one the good magazines that they dyno'd them and got i think it was about 5 hp to the wheels. so i guess it's true!
Old 01-30-2002, 11:41 AM
Spunkymonkey's Avatar
Spunkymonkey Spunkymonkey is offline
I thought that NGK made some Iridium Sparks themselves? I've seen the ads in the magazines. I'm not sure if they do much, but I believe they cost like $20 each or something and are more suited to harder driving, and likely to last longer.
By the way head back over to the Asia/Pacific forum to say hello to everyone again Tim
Has the lude got the Mugen kit on yet...post some pics up
There's a chick driving that thing
www.performanceforums.com
Old 01-30-2002, 04:41 PM
fritz_269's Avatar
fritz_269 fritz_269 is offline
NGK makes two flavors of Iridium plugs, unfortunately none are sized right for the H22A (at least for now).
Denso reccommends their part #IK20 for the H22A4 with the gap set to 0.044" (1.1mm) with the stock ignition.
If your engine is fairly stock (only bolt-ons) and the OEM NGK platinums are in good condition, I honestly doubt you'll see much of a power increase. But they won't hurt, and they seem to be well made from the reports I've heard. And they should last for forever and a day. They can be had for around $15 each.
Old 01-30-2002, 05:39 PM
4bidden 4bidden is offline
Send a message via AIM to 4bidden
from what you said fritz it sounds like that if you have an aftermarket ignition you should gap your plugs different. is this true?
-Jeremy | [email protected]
Old 01-30-2002, 06:48 PM
texan's Avatar
texan texan is offline
Writer Mod
If you can make greater voltage, yes it's true. Once the spark has jumped the gap additional voltage makes no significant increase in spark size, but increasing the gap along with enough voltage to jump it certainly does. Companies love to show pictures of how "hot" the spark is and so forth, but I've seen better evidence that increasing the gap with a strong coil makes much more difference in power output than just increasing the voltage. Also remember this is assuming there's something inadequate about the current setup, which if the motor is NA and fairly stock is not the case.
'03 Corvette Z06
'99 Prelude SH
Old 01-31-2002, 01:56 AM
MARKUSIUDIUS MARKUSIUDIUS is offline
Well boys
I actually have the part number for the NGK Iridium plugs for a H22A. It is ZFR6FIX-11 same from 94 to present. $18.95 each AUS:flash:
1994 2.2lt Jap import Vtec, Blown with a 1GGZE charger 300Hp or 220+kw
Malpassi Reg, 500 injector, Unichip piggyback management system, Top gun leads, Map controller, Vtec controller, Custom FM Cooler, Custom fast flow exhaust and weight reduced (2640pds)
Old 01-31-2002, 09:17 PM
Re: Well boys
how about the part# for the h23a1?? do you have that?
Old 02-01-2002, 12:30 AM
So basically we're stalemated about any performance increases... some say yes, others say no... I'd be very interested if anyone can find the figures for putting them in a stock(ish) H22A..
Old 02-01-2002, 01:17 AM
Sorry
Sorry Rybred no I dont, ring your parts dealer> :flash:
Old 02-01-2002, 01:41 PM
fritz_269's Avatar
Re: Well boys
Cool. They haven't updated their web catalog with that part number yet, so as you said, you'll probably have to call them or a dealer.
http://www.ngksparkplugs.com
Iridium spark plugs dougb2 Venture 4 09-13-2009 02:17 PM
spark plugs freakyfire05 ZX2 2 02-17-2009 11:03 AM
Iridium Spark Plugs.. ToyotasRULE Maintenance 1 04-22-2004 03:16 PM
Installed; NGK IRIDIUM SPARK PLUGS - BKR5EIX11 jbrionesx Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 0 06-06-2003 11:14 AM
Iridium spark plugs. Polygon Street Racing 1 07-15-2002 08:15 PM
