Old 01-24-2002, 02:47 PM
Davidov Speed WRC Davidov Speed WRC is offline
Send a message via AIM to Davidov Speed WRC
Unhappy Fuses??
This morning I was on my way to school and I noticed my Tach, Clock, Turn Signals, Temp Gauge, and Fuel Gauge were all dead, however my speedometer worked.
Later me and my friend found it was a fuse that was blown, so I replaced it with one that was provided in the Fuse Box.
Well after about 15 minutes of driving, all those same things go out, which really pissed me off.
I had my defroster, heater, and headlights on, so I wondered if having all those on surged the fuse??
What would cause two fuses to blow within that amount of time?
Old 01-24-2002, 10:57 PM
Gasoline Fumes Gasoline Fumes is offline
According to my manual, that fuse (#3, 10 amp) powers the following things.
warning lights
clock
chime
gauges (except speedo, it's mechanical)
back up lights
turn signals
I would first check the bulbs and sockets for the turn signals and back up lights. Look for corrosion or a broken bulb. If they all look OK, try disconnecting the other compenents one at a time. Whatever you do, don't try to "fix" it with a higher amp fuse.
My Website
Old 01-26-2002, 12:21 PM
Ok, thanks, it was that fuse, and the one I replaced it with was bad too, so it blew just as fast.
I bought a pack of 5 new ones for $2.13, and one fuse fixed it.
98 Camaro electric and fuse issues Rkeefer23 F-Body Problem Diagnosis 2 12-20-2009 01:00 PM
fuse after fuse after fuse after fuse after fuse D-Bo 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 2 08-06-2005 03:15 PM
Power lead to extra blade fuse in main fuse box bufpilot Odyssey 0 11-25-2003 10:25 AM
Radiator fan fuse has NO power under hood fuse box! Hybrid93Hatch '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 04-20-2003 06:25 AM
2000 Jetta fuse box? I think tail light fuse is blown... PSORC1 '97 - '03 0 10-12-2002 06:23 PM
